23 страниц V « < 10 11 12 13 > »
Elektro255 V0.4 alpha 4 mod (4xR), 44R,46R,49R,79R
elektro255
сообщение 23.9.2006, 12:06 Закрепленное сообщение!
Из: Poland, Siedlce
Пользователь №: 53 130
09-04-2007
V0.4a4 Alpha: http://elektro255.ovh.org
08-04-2007
V0.4a3 Alpha: http://elektro255.ovh.org
07-04-2007
V0.4a2 44R Alpha: http://elektro255.ovh.org
20-12-2006
V0.3 79R Final mod: http://elektro255.ovh.org
27-11-2006
v0.3 for 49R Final mod http://elektro255.ovh.org/
26-11-2006
V0.3 46R Final mod: http://elektro255.ovh.org
НА Е1 Rokr с бутом 0А02 (оригинальный) НЕ ПОСТАВИТЕ БЕЗ Т.П.!
V0.4 alpha 4
Changes:
- Fixed problem with display timeout (fullscreen clock) when SMS/CALL received
Features:
- 4xR and 7xR MIX (use with 4xR flex)
- unlimited Video recording
- keypad automatic lock
- low battery alarm can be turned off or depend on ring style.
- Scheduled Ring Styles (ring style and funlight style can change automatically on given time and week day)
- flashlight shortcut (##)
- extra menu (shortcut *1 [shortcut is only for testing later will be changed])
- automatic menu enter, without sim card (emergency calls working too)
- new Java methods
- settings are stored on files
- no simlock checking
- Volume-bar sound can be turned off
- multiple menus (every skin can have one mma_ucp)
- Ported patches:
o SMS report significantly turned ON
o more folders in OBEX via BT
o removed unused folders from TransFlash
o Java have access to system files
o increased iTap user dictionary size
o no delete incall on SIM replace
o Bluetooth time changed to 3 minutes
o reordered camera store menu (store only is first)
o SMS alert is using default ringtone
OLD versions(V0.1-0.3):
Firmware changes:
- firmware based on 46R from StarterXP MP
- FULL SW access from Java
- LUMA&CHROMA tables moved to memory - now you can change JPEG compresion from Java
- StarterXP flex
- added dualboot
Flasher changes:
- if you have PDS_4013 flasher will no recreate this
Personalization tool changes:
- first version for 0.3_46R SW mod
- changing splash screen
- changing font (you can use *.fnt or *.smg CG4 files)
- you can turn on, turn off menu access without sim cart
- changing my shortcuts
Новая версия V0.4 alpha 4
Изменения:
- Устранена проблема с таймаутом дисплея(полноэкранные часы) при приеме смс/звонка
Новое:
- Прошивка создана как микс 4xR и 7xR (флекс 4xR ) В 44R она переименована для совместимости! Она близко не лежит к 44R на самом деле!
- Безлимитная запись видео (64мб макс как в 6х7х)
- Автоблок клавиатуры
- Звук разряженой батареи можно выключать или задать стилем оповещения(?).
- Расписание стилей оповещения (стиль оповещения и фанлайтмогут менятся автоматически по времени и дням недели)
- Фонарик по (##)
- Дополнительное меню (метка *1 [только для теста, после может изменится])
- Автоматический вход в меню без сим-карты (аварийные звонки работают)
- Новые методы в Яве (не от 79R, а новые)
- Настройки хранятся в файлах
- Не проверяется лоченость ПДС на симку (работает с лоченым пдс)
- Звук изменения громкости можно отключить
- Мультименю (каждый скин может иметь собственный мма_уцп)
- Портированы патчи:
o Оповещение о доставке SMS всегда вкл.
o больше папок доступно по OBEX из блютуза
o удалены неиспользуемые папки с флешки
o Полный доступ к системным файлам из явы
o увеличен размер пользовательского словаря iTap
o не удалыются последние вызовы при смене сим
o Время обнаружения блютуза - 3 минуты
o Меню сохранения видеозаписи (просто сохранить - первым пунктом)
o при приходе SMS играет "мелодия на смс", а не установленная на этого пользователя
Для версий 0.1-0.3
Изменения в прошивке:
- Создана на базе монстра StarterXP 46R
- Полный доступ к прошивке (симы, озу) из явы
- Таблицы сжатия фотографий перенесены в озу - теперь из явы можно управлять качеством фотографий (сжатием)
- флекс StarterXP
- добавлен дуалбут
Изменения флешера:
-Если ПДС версии 4013 (373 платформа), ПДС не пересоздается.
Изменения персонализации (Personalization tool):
- впервые для мода использована 46 прошивка
- замена заставки (на включение?)
- замена шрифта (лангпак, CG4)
- можно вкл. и выкл. доступ к меню без сим-карты
- изменен ярлык (копирайт?)
Для работы Personalization tool требуется положить в папку программы несжатый бинарный бэкап (32 мегабайта) под именем SW.bin
Прекращаем флудить, типа а когда выйдет новая версия, и.т.д.и.т.п, или придётся наказывать!
тему почистил, архив по 1 декабря тут:
Прикрепленный файл MotoFan_ru_electro.zip   ( 66.56 килобайт ) Кол-во скачиваний: 3902
Сообщение отредактировал elektro255 - 9.4.2007, 12:21
deadmoto
сообщение 14.1.2007, 17:19
Главный Новостник
Из: Омск
Пользователь №: 49 284
Модель телефона: Motorola
Прошивка: Motorola Original
Запускаем P2K Tools > Seem Editor > 005b_0001
Находим строку 010... По этой строке столбец 05 это кнопка слева, 06 - кнопка справа...
В архиве найдёшь значения клавиш... У меня 010х05 стоит 42, 010х06 стоит 3F...
Желаю удачи, пробуй...
После некоторых раздумий... Если всё же поставиш на инт.клавишу корелет(код 42), то он будет вызываться из любого места в телефонеsmile.gif Т.е. аналог такой же кнопки не Е1...
Я тебе сейчас -2 дам Запрещено выпрашивать рейтинг
Сообщение отредактировал deadmoto - 15.1.2007, 7:08
Bent
сообщение 15.1.2007, 5:17
MoTo Marvellous
Пользователь №: 63 874
Doktor Кот,
А еще как на этой проше дуалбут запустить?
Зажимаешь "Зелёную кнопку" и буквально на секунду(отрывистым движением) нажимаешь "Красную"(Зелёную держишь всё время,не отпуская) Само собой проделывать это в выключенном состоянии.
Еще хочу спросить, какая проша от Электро самая хорошая, самая стабильная и новее: 79R или 49R?
На мой взгляд лучше 49R79R много заморочек(хотя,сейчас посмотрим что там за RC3 выйдет),НО на 79R безлимитное видео.
AgentSlash
сообщение 15.1.2007, 12:35
Из: Ukraine, Kyiv
Пользователь №: 46 621
Модель телефона: HTC Touch Diamond
Цитата(Doktor Кот @ Воскресенье, 14 Января 2007, 14:58)
.......Еще хочу спросить, какая проша от Электро самая хорошая, самая стабильная и новее: 79R или 49R?
Всё таки 79 получше будет. Токо ставить тебе лучше не голую електровскую прошу, а какой нить настроеный и пропатченый монстрик. Советую подождать симбу от Арчи (RC3).
Doktor Кот
сообщение 15.1.2007, 15:38
Из: Красноярск
Пользователь №: 94 751
Прошивка: Electro_R373...49R
Deadmoto, спасибо! Помог! лови + И за отзывы спасибо всем! Еще столкнулся с такой проблемой: изначально на проше от Электро стоит 2 скина: WindowsXp_olive и просто WindoаsXp. Заметил, что эти два скина - полные. WindowsXp_olive - это главный скин, мне он не нравится и я его удалил. И теперь когда я заливаю какой-нибудь другой скин, больший по размеру чем скин WindowsXp, этот скин (а он конечно же неполный) становится главным и пропадают пункты меню! А как сделать родной скин Windowsxp - главным?
BackgaMan
сообщение 15.1.2007, 17:29
Мотоумелец
Пользователь №: 61 651
Модель телефона: E-398 Htc-p3300
ММА попробуй от этого скина закинь.
Bent
сообщение 16.1.2007, 4:51
MoTo Marvellous
Doktor Кот,
Открываешь через p2ktools папку со скином,выделяешь все файлы внутри папки Windowsxp,ставишь им атрибут - "Системный",перезагружаешься.
PATRON2002
сообщение 17.1.2007, 20:04
Из: Ростов-на-Дону
Пользователь №: 72 038
Модель телефона: Nokia 6120c
Прошивка: Symbian 9.2 3Dr
Дайте плиззз патч для передачи ЯВЫ по блютузу через папку видео....
deadmoto
сообщение 17.1.2007, 20:52
Главный Новостник
Из: Омск
PATRON2002, Держи...
PATRON2002
сообщение 18.1.2007, 18:03
Из: Ростов-на-Дону
Глюк с отправкой смс! Поставил более мелкий шрифт..........И почемуто когда отправляешь смс,то получателю приходят только знаки припинания.Да и на родном ленге смс не отправляются. А латинские буквы доходят нормально.
*НеХеR*
сообщение 18.1.2007, 20:58
Пользователь №: 74 787
Прошивка: 2.3.4
PATRON2002,
Ну уже не раз писали по всему мотофану, в п2к тулзе, в "скрытых настройках" включи "юникод в смс" и все.. если что не ясно, то поищи по форуму.
go-blin
сообщение 22.1.2007, 17:40
Из: Башкирия,Октябрьский
Пользователь №: 48 665
Модель телефона: i900
Прошивка: WM6.5.3
Мне кажется, что тема переходит во флуд. Дайте патч, дайте ленг. Все необходимое для доводки находится в соответствующих темах. Пора чистить!
Ты сам то не флуди,твоё сообщение по твоему информативное? Не волнуйся,когда нужно почистим.
Сообщение отредактировал Bent - 23.1.2007, 7:05
RXLexus
сообщение 23.1.2007, 18:53
Пользователь №: 115 240
Прошивка: electro v0.3
Подскажите, как фойти в меню опкодов? Просто хочу восстановить утерянные вх-исх вызовы.. через опеод прочитал на форуме делается. Вот что пишут...
"Делается через опкоды 47 - 421(422) - 1- 0 - 2 - 255255 - перегруз."
Bent
сообщение 24.1.2007, 5:55
MoTo Marvellous
RXLexus, Войти так: Меню + 048263 + * или Меню + 0
Maxval
сообщение 25.1.2007, 18:03
Из: Perm
Пользователь №: 67 892
Модель телефона: E 398
Прошивка: MotoWalkman49R EM
I just done reversing both 46R and 49R elektro's MP with manually applied RSA patch ... I found that elektro really did something to the firmware CG1 area. I hope these files works on ROKR as it did on E398.
NOTE : these files might brick your phone since it was fully patched from the original elektro's MP manually. Both files do not contain a language pack. Please make a backup before flashing. Flash these at your own risk.
1) elektro's v0.3 46R for E1 with RSA patch (46R fullflash excluding LP)
2)elektro's v0.3 49R for E1 with RSA patch и еще одна ссыла
3) elektro's v0.3 flexlash (extracted from v0.3 49R) -> if you just want the flex.
All files are in .shx format and can be flash using any flasher software you have.
If these files are worthless (bricking the phone,etc), I will remove them as soon as possible.
regards
note : all credits should go to the MP makers for their passion on making such wonderful MPs. I am just trying to help others enjoying their work.
цитата aze2learn с motomodders
gadzellist
сообщение 27.1.2007, 20:26
Из: ростов-на-дону
Пользователь №: 111 586
Модель телефона: e 1
Прошивка: New Standart
поставил прошивку,и на некоторых ява приложениях на карте памяти стало писать что 'приложение истекло.проверьте дату и время в исходныхнастройках' что нужно сделать,чтобы заработало????
-mak-
сообщение 28.1.2007, 6:08
Из: Город-герой Волгоград
Пользователь №: 56 604
Модель телефона: qtek s200
regards
Сделана CG1 от электро портирована для оригинального РОКР Е1, написано, что тестовая версия, кто не боится - пусть пробует, шьется чем угодно. Прошивка не содержит лэнга
Если работает - сообщите
РАБОТАЕТ. Протестировано Don Omar. С неё можно слезть обратно стандартным монстром для Е1 (полным)
Сообщение отредактировал AlexKooper - 2.2.2007, 11:23
Neo31337
сообщение 1.2.2007, 19:20
Из: Зеон
Пользователь №: 115 765
Модель телефона: RokR E1 без ТП
Прошивка: Elektro 255 49R
Ждем тестов очень!!! На всяк случай скачайте ато вдруг им взбредет файл удалить...
czShaDoW
сообщение 7.2.2007, 21:29
Пользователь №: 117 034
Прошивка: Mpx_e398[Final]_49R
Помогите сделать с помощью опкодов на рокр е1 60 исх и вхд, заранее спасибо!
Valeo
сообщение 7.2.2007, 21:31
Going eternally
Из: Україна. м. Чернігів
Пользователь №: 46 805
Модель телефона: 1
Дата поощрения/наказания
Включение отображения 60 входящих/исходящих вызовов через опкод
60 Входящих
Bxoдим в мeню "Opcode"
жмем
Meню
затем 048263*
Bвoдим знaчeния:
Opcode "47" "OK"
Field 1 "80" "OK"
Field 2 "1" "OK"
Field 3 "143" "OK"
Field 4 "1" "OK"
Field 5 (D) "060" "OK" (понятно, что 060 - это 60 вызовов, можно 020 - будет 20 вызовов)
->Oтkaт: Field 5 (D) "010" "OK"
Results
F1 : 0 перезагрузка телефона
60 Исходящих
Opcode "47" "OK"
Field 1 "80" "OK"
Field 2 "1" "OK"
Field 3 "147" "OK"
Field 4 "1" "OK"
Results
Neo31337
сообщение 8.2.2007, 8:56
Из: Зеон
Все я поставил! все отлично работает даже СИГ ЭРРОР не дало! Смею заметить что у меня РокР Е1 без ТП! фонарик потестил. Скины мне не нравятся но я их заменю ДРМ тоже так себе надо бует доделать вид отправки сообщений тид итп. Мне лично нравяться с 2Pac Революшн Мода. Ждите постов от меня как потестю выдам результаты. Шиться мона без проблем, не забывая о бекапе.
Doktor Кот
сообщение 8.2.2007, 10:18
Из: Красноярск
Чет от Электро ничего не слышно и не видно! Кто нить знает, когда что нибудь новенькое Электро выдаст?
deadmoto
сообщение 8.2.2007, 13:35
Главный Новостник
Из: Омск
Doktor Кот, следующее скорее всего будет в т.ц. на V360.
X3MAL
сообщение 8.2.2007, 16:52
Из: Украина, Александрия
Пользователь №: 79 325
Модель телефона: MotoMing
Прошивка: Antarex Mod 14R
А при прошивке Е1 на него также можна будет патчи ставить?
Яуген
сообщение 8.2.2007, 17:04
Пользователь №: 101 871
X3MAL, он только для е398:)
Maxval
сообщение 8.2.2007, 19:06
Из: Perm
X3MAL,
можно, только скачай версию для е1
=BazOOka=
сообщение 9.2.2007, 21:21
Пользователь №: 107 478
Модель телефона: rokr e2
Прошивка: 4AP
Кто-нить, дайте ссылки на 49r for rokr e1 без ленга, которые не с рапиды! Пожалста!
Наглый флуд.Ещё раз увижу подряд 8 сообщений об одном и том же, получишь моментальный БАН.
Bent, извиняюсь. Просто форум у меня вчера после отправки постов глючил, выкидывал куда-то. Вот я возвращался и отправлял опять. Просто не думал, что они отправились.
Сообщение отредактировал bazooka47 - 10.2.2007, 11:34
SANYO_K
сообщение 11.2.2007, 2:05
Пользователь №: 64 324
Модель телефона: ROKR E1 (E398)
Прошивка: elektro255!!! 49r
А на прошу для E1 со снятым RSA пробовали ставить DualBoot ??
Neo31337
сообщение 11.2.2007, 12:54
Из: Зеон
Так, потестил я этот мод для Е1. Вот те минусы что я заметил:
1. ДРМ не ахти можно было и получше
2. при поиске по справочнику постоянно включен Айтап и нет функции его вырубить
3. даже при входе джаву реклама сайта ЭЛЕКТРО
4. скины под оригинал виндовс ХР
5. значки при наведении на них курсора сильно терябют в качестве
6. гейн тейбл не хороший
7. синердж не пашет (ни тебе клавблока, ни контроля компресии фоток)
8. на клавишу камеры теперь монанастраивать что угодно а вот на реальную интелеектуальную клавишу настроенн голосовой набор и диктафон
Если кто знает как с этим всем разобраться пишите буду ждать!
Bent
сообщение 12.2.2007, 5:11
MoTo Marvellous
Neo31337,
2. Faq - Все Вопросы И Ответы По Шрифтам И Лэнгу
3. Убирается в DRM картинка №18
San3k
сообщение 14.2.2007, 7:01
Пользователь №: 108 480
Модель телефона: Nokia 5310; E398
Подскажите что лучше сделать:
прошиться на електоромод 79р? (с сайта электро не качает FullSW with 1-click flasher, где еще можно скачать?)
или поставить рефлеш на мпх398 49р финал?
Ratmagor
сообщение 14.2.2007, 21:48
Из: Мск
Пользователь №: 59 289
Модель телефона: Motorola Moto Maxx
Прошивка: KitKat
San3k,
Лучше прошиться модом от Электро на 49Р, а потом прошить всё, кроме CG1 от mpx398...
Лично мне показалось, что скорость работы на 79 ниже (причем ощутимо) чем на 49.
Тестов не проводил, ориентируюсь только на собственные ощущения..
San3k
сообщение 15.2.2007, 11:24
Скачал elektro255mod v0.3 49R как его поставить? Нужно откатиться на свой бекап и шиться или как? Напишите плиз подробно...
Ratmagor
сообщение 15.2.2007, 11:46
Из: Мск
Прошивка: KitKat
Делаешь бэкап. Если до этого ставил 42 for all, то прошивай родной и потом шейся по мануалу от Sanyok_ минуя 42 for all, чтоб сохранить настройки аккума..
Motofan_is_cool
сообщение 19.2.2007, 17:28
Пользователь №: 78 792
Поставил v0.3 for 49R а глюк в SMS .Пишеш SMS все норм а отправляются только цифры и знаки препинания русские буквы не отправляются.
Как лечить?
Moto_Chip
сообщение 20.2.2007, 0:08
Пользователь №: 70 398
Модель телефона: E398->E1
Прошивка: R_373_49r + ИМХО...
Motofan_is_cool,
Включи Юникод в СМС сообщениях ! С помощью нпример П2К тулс
ROMANI89
сообщение 25.2.2007, 2:12
Из: новосибирск
Пользователь №: 106 535
Модель телефона: MOTOROLA E398
Прошивка: MOTOSYMBYAN 1.5 RC3
здравствуйте, у меня такой глюк, когда загружается мв 0,35 , когда он в фоне, при нажатии клавиши меню тел перезагружается. у меня такие догадки почему это происходит, я помянял сим 005b_0001 он был настроен так: принажатии на клавишу гарнитуры срабатывало действие джойстик вверх, а при входящем вызове поднимал трубку. еще я поставил мв 0,35 .когда в мв не запущен плагин информаор все нормально.. так же заменил скины. вроде больше ничего не менял.что может быть? еслив это глюк сима, то выложите пожалуйста этот сим оригинальный .
OsVal
сообщение 28.2.2007, 7:31
Из: г. Орск
Пользователь №: 58 961
Модель телефона: Моторола E-398 -> E1
Прошивка: R373_G_0E.30.79R
Неделю с небольшим назад поставил монстра V0.3 79R Final mod. Шрифт для меня мелковат, поэтому прошил лэнг со стандартным шрифтом и соответственно заменил скины. Пока все работает нормально, по крайней мере те функции, что я использую: звонки, интернет, медиа, фото, видео. Стоит MV v. 1.0 с плагинами инструменты книги, SMS@sender, диктофон, funlight, читалка, погода, senergy, midletlist, filechanger, soundeditir. Все работают нормально. SMS не бэкапит, но возможно из-за названия телефона, вроде бы ему надо дать определенное имя, а какое, я забыл и искать лень. Минусов нашел пока только два: не видит из соответствующего меню и не ставит на звонок файлы аас (.m4a) - для меня несущественно, и батарея, которая на 49R держала 2-е суток, сейчас не тянет при той же нагрузке и одного дня - это напрягает. И после недельной дрессировки батареи пока не вижу существенных улучшений. Еще с недельку потерплю, если батарея так и будет держать меньше суток, откачусь обратно на v0.3 for 49R. Для меня двухдневная батарея предпочтительнее безлимитного видео, которое еще неизвестно, понадобится ли. rolleyes.gif
OsVal
сообщение 1.3.2007, 11:53
Из: г. Орск
01.03.07 Обнаружился еще один глюк - при соединении с компом по блютусу не хочет включаться служба FTP, хотя между телефонами файлы передаются без проблем. В то же время служба диал-ап работает нормально и с инетом вполне можно работать. У кого-нибудь еще есть такое.
ЗЫ. Вечером попробую соединить с другим компом для контроля.
OsVal
сообщение 2.3.2007, 8:26
Из: г. Орск
Проверил на другом компе, также по блютусу не хочет включаться служба FTP. Откатился на 49R, БТ заработал нормально.
DED_MOPO3
сообщение 3.3.2007, 10:16
Из: Земля-Россия-Воронеж--РОССОШЬ
Пользователь №: 115 566
Модель телефона: N73 me
Прошивка: V 4.0745.2.0.1RM 133
Дайте пожалуйста другую ссылку на скачку 79r , а то на сайте электро255 глюк какой - то!!! sad.gif
Текстовая версия Сейчас: 24.7.2025, 3:00
