23 страниц V « < 11 12 13 14 > »
Elektro255 V0.4 alpha 4 mod (4xR), 44R,46R,49R,79R
elektro255
сообщение 23.9.2006, 12:06 Закрепленное сообщение!
Из: Poland, Siedlce
Пользователь №: 53 130
09-04-2007
V0.4a4 Alpha: http://elektro255.ovh.org
08-04-2007
V0.4a3 Alpha: http://elektro255.ovh.org
07-04-2007
V0.4a2 44R Alpha: http://elektro255.ovh.org
20-12-2006
V0.3 79R Final mod: http://elektro255.ovh.org
27-11-2006
v0.3 for 49R Final mod http://elektro255.ovh.org/
26-11-2006
V0.3 46R Final mod: http://elektro255.ovh.org
НА Е1 Rokr с бутом 0А02 (оригинальный) НЕ ПОСТАВИТЕ БЕЗ Т.П.!
V0.4 alpha 4
Changes:
- Fixed problem with display timeout (fullscreen clock) when SMS/CALL received
Features:
- 4xR and 7xR MIX (use with 4xR flex)
- unlimited Video recording
- keypad automatic lock
- low battery alarm can be turned off or depend on ring style.
- Scheduled Ring Styles (ring style and funlight style can change automatically on given time and week day)
- flashlight shortcut (##)
- extra menu (shortcut *1 [shortcut is only for testing later will be changed])
- automatic menu enter, without sim card (emergency calls working too)
- new Java methods
- settings are stored on files
- no simlock checking
- Volume-bar sound can be turned off
- multiple menus (every skin can have one mma_ucp)
- Ported patches:
o SMS report significantly turned ON
o more folders in OBEX via BT
o removed unused folders from TransFlash
o Java have access to system files
o increased iTap user dictionary size
o no delete incall on SIM replace
o Bluetooth time changed to 3 minutes
o reordered camera store menu (store only is first)
o SMS alert is using default ringtone
OLD versions(V0.1-0.3):
Firmware changes:
- firmware based on 46R from StarterXP MP
- FULL SW access from Java
- LUMA&CHROMA tables moved to memory - now you can change JPEG compresion from Java
- StarterXP flex
- added dualboot
Flasher changes:
- if you have PDS_4013 flasher will no recreate this
Personalization tool changes:
- first version for 0.3_46R SW mod
- changing splash screen
- changing font (you can use *.fnt or *.smg CG4 files)
- you can turn on, turn off menu access without sim cart
- changing my shortcuts
Новая версия V0.4 alpha 4
Изменения:
- Устранена проблема с таймаутом дисплея(полноэкранные часы) при приеме смс/звонка
Новое:
- Прошивка создана как микс 4xR и 7xR (флекс 4xR ) В 44R она переименована для совместимости! Она близко не лежит к 44R на самом деле!
- Безлимитная запись видео (64мб макс как в 6х7х)
- Автоблок клавиатуры
- Звук разряженой батареи можно выключать или задать стилем оповещения(?).
- Расписание стилей оповещения (стиль оповещения и фанлайтмогут менятся автоматически по времени и дням недели)
- Фонарик по (##)
- Дополнительное меню (метка *1 [только для теста, после может изменится])
- Автоматический вход в меню без сим-карты (аварийные звонки работают)
- Новые методы в Яве (не от 79R, а новые)
- Настройки хранятся в файлах
- Не проверяется лоченость ПДС на симку (работает с лоченым пдс)
- Звук изменения громкости можно отключить
- Мультименю (каждый скин может иметь собственный мма_уцп)
- Портированы патчи:
o Оповещение о доставке SMS всегда вкл.
o больше папок доступно по OBEX из блютуза
o удалены неиспользуемые папки с флешки
o Полный доступ к системным файлам из явы
o увеличен размер пользовательского словаря iTap
o не удалыются последние вызовы при смене сим
o Время обнаружения блютуза - 3 минуты
o Меню сохранения видеозаписи (просто сохранить - первым пунктом)
o при приходе SMS играет "мелодия на смс", а не установленная на этого пользователя
Для версий 0.1-0.3
Изменения в прошивке:
- Создана на базе монстра StarterXP 46R
- Полный доступ к прошивке (симы, озу) из явы
- Таблицы сжатия фотографий перенесены в озу - теперь из явы можно управлять качеством фотографий (сжатием)
- флекс StarterXP
- добавлен дуалбут
Изменения флешера:
-Если ПДС версии 4013 (373 платформа), ПДС не пересоздается.
Изменения персонализации (Personalization tool):
- впервые для мода использована 46 прошивка
- замена заставки (на включение?)
- замена шрифта (лангпак, CG4)
- можно вкл. и выкл. доступ к меню без сим-карты
- изменен ярлык (копирайт?)
Для работы Personalization tool требуется положить в папку программы несжатый бинарный бэкап (32 мегабайта) под именем SW.bin
Прекращаем флудить, типа а когда выйдет новая версия, и.т.д.и.т.п, или придётся наказывать!
тему почистил, архив по 1 декабря тут:
Прикрепленный файл MotoFan_ru_electro.zip   ( 66.56 килобайт ) Кол-во скачиваний: 3902
Сообщение отредактировал elektro255 - 9.4.2007, 12:21
Trentemoller
сообщение 19.3.2007, 15:23
Из: Армавир
Пользователь №: 105 953
Прошивка: R373_G_0E.30.49R
ApxuBatop,
Если допустим я выдерну свои gain и param table с 49r и залью их на 79r, останится ли звук прежним или изменится!? Патчи может быть и есть, но искать их опять же долго, дорабатывать самому. Еще очень нехочу ставить из-за глюков, перечисленные Side`ром.
Сообщение отредактировал Trentemoller - 19.3.2007, 15:25
=BazOOka=
сообщение 19.3.2007, 15:29
Пользователь №: 107 478
Модель телефона: rokr e2
Прошивка: 4AP
Цитата(Trentemoller @ 19.3.2007, 18:23) *
ApxuBatop,
Могут быть и глюки, а может нормально влезть.
Nogay
Из: Фёдоровка, Сургутский район
Пользователь №: 83 007
Прошивка: Mpx398 De Luxe
Trentemoller, если ты поставишь gain и param от 49R на 79R, то звук будет не очень, т.е. не будет такого звука как на 49R.
ToJlcTblu
сообщение 19.3.2007, 15:57
Из: Краснодарский край г.Лабинск
Пользователь №: 105 576
Прошивка: R373_EM3_49R
Пробовал ставить патчи но ничего ощутимого не происходит. Все остается как и было! По-моему, этот мод вообще патчиться не хочет. Или я неправ?
Сообщение отредактировал ToJlcTblu - 19.3.2007, 21:42
ApxuBatop
сообщение 19.3.2007, 16:05
Мото-Художник
Пользователь №: 65 512
Модель телефона: iphone 5
Прошивка: от Е398
Цитата(Trentemoller @ Сегодня, 18:23)
ApxuBatop,
Просто адаптируй param_table.bin с помощью Motosound : Звук На Любую Motorola =) а gain_table.bin не трогай.
elektro255,
It's great! Maybe interface is not so good, but firmware changes are excelent.
I advice you to look thought this topic: Переключаем Скоростя в Телефоне на Повышенные ! Motospeed , here Osta discovered, that in DRM is located timings table that allow us to speed our phone. smile.gif
I made patch for DRM for 0.4a...
Прикрепленный файл electro255_0.4a_optimum_speed_by_ApxuBatop.rar   ( 446 байт ) Кол-во скачиваний: 388
And i see, that video playback is rather faster, than in previous versions and firmwares... clap.gif
Короче, народ, вот патч для уменьшения таймингов телефона для ускорения передвижения по меню
и звуковой патч MegaBass...
Прикрепленный файл electro255_0.4a_MegaBass_by_ApxuBatop.rar   ( 33.5 килобайт ) Кол-во скачиваний: 356
Как включить wav звуковое оформление читаем тут: Все о телефоне Motorola E398 (6.1 Озвучка клавиш)
В этой прошивке видео воспроизводит гораздо быстрее и без тормозов идет Simple @L3 в скрипте ... Рекомендую! smile.gif
Сообщение отредактировал ApxuBatop - 19.3.2007, 17:47
deadmoto
сообщение 19.3.2007, 18:51
Главный Новостник
Из: Омск
Пользователь №: 49 284
Модель телефона: Motorola
Прошивка: Motorola Original
elektro255, I can't access java permissions)))
no more Java permissions, corelet signs and certificates !
Jimm and Bombus told me that access to socket denied)
MiniCommander hangs on 4th circle - when reading FS)
San3k
сообщение 19.3.2007, 18:57
Пользователь №: 108 480
Модель телефона: Nokia 5310; E398
А русский langpack нормально ставиться на 0.4?
=BazOOka=
сообщение 19.3.2007, 18:59
Прошивка: 4AP
deadmoto, просто дай права Minicommander (через motomidman).
Не знаю почему, но когда эту прогу ставят в монстр, она там без прав (почти на всех).
Trentemoller
сообщение 19.3.2007, 19:14
Из: Армавир
Я думаю надо выложить здесь список багов на Английском для electro, чтобы ему было понятно, что надо исправлять!
Side
сообщение 19.3.2007, 19:32
Из: Мурманск
Пользователь №: 81 705
Модель телефона: V535, EM30
To elektro255
I think that i find error in srs_editor
I do this:
1) Open file
2) Clear
3) Select 0-None 4-Silent
4) Clear day of week field
5) Enter time 23 00
5) Press Add
In result list i see this: 23:00 -> Vibe then Ring|None
If i don't select day of week ringstyle always was: ringstyle=dec(ringstyle)
Do it possible to add without day of week?
San3k
сообщение 19.3.2007, 20:09
Кстати, без разницы какой программой прошивать?
Vadim Velikii
сообщение 19.3.2007, 20:49
Пользователь №: 102 604
Модель телефона: ROKR_E398, v360, v8
Прошивка: 49E.m.
San3k, без разницы. Флешбекапом проще всего.
DarkNeo
сообщение 19.3.2007, 21:54
Пользователь №: 93 559
Модель телефона: Nokia 6680
Эм...прошился...теперь проблема - не могу использовать GPRS в Java (ICQ, jMailAgent)..
пробовал переустанавливать приложения, полностью давать разрешения на доступ через плагин в MV и с компа (через MMM)... не помогло. GPRS-сессия даже не открывается..
При этом в SMS@Sender GPRS работает нормально...
в чем проблема?
to elektro255:
After flashing I can't use GPRS in my Java apps... I'd tried to reinstall midlets...give them all permissions (through MotoMidMan)..no effect!
I'd turned off GPRS Auto Attach.. so I can see, when GPRS session is opened..
so..
seems that SMS@Sender opens GPRS-session and sends data OK... but midlets can't do this..
what's the problem?
Добавлено позже (20.3.2007, 3:02):
Кто-нибудь сталкивался с такой проблемой?
ToJlcTblu
сообщение 19.3.2007, 23:31
Такая же фигня! Пробовал через стандартный браузер - сессия открывается но при этом ничего не происходит. И в итоге передано 0 байт. При открытии сессии через комп работает гдето с пол часа и перезагружается. И с каждым разом всё чаще и чаще.
При попытке изменить базовую клавишу вверх - тело тоже перезагружается.
Vadim Velikii
сообщение 20.3.2007, 0:09
Прошивка: 49E.m.
Электро255 выложил на своём сайте документацию, программы и файлы для мода 0.4а!
Сообщение отредактировал Vadim Velikii - 20.3.2007, 0:11
SANYO_K
сообщение 20.3.2007, 0:58
Пользователь №: 64 324
Модель телефона: ROKR E1 (E398)
Прошивка: elektro255!!! 49r
What about SMSBackUp? Does it work on this version of 79r?
Doktor Кот
сообщение 20.3.2007, 2:14
Из: Красноярск
Пользователь №: 94 751
Прошивка: Electro_R373...49R
Вот, вот, без SMSBackUp я даже и не подумаю эту прошивку ставить. Да и глюков в ней много.
66_ЛЁХА_99
сообщение 20.3.2007, 3:13
Пользователь №: 108 652
Модель телефона: Motorola ZN5
Прошивка: R6637 G 81 03 0ER
iTap в русском шрифте не работает, он есть, но никаких слов не знает!!! Устанавливал другие лэнги, но ничего не меняется sad.gif
При попытке назначить на клавишу джойстик вверх будильник, телефон переходит в ребут unsure.gif
Вправо поставил стили оповещений, но там так и осталась основная настройка, после перезагрузки всё стало как надо stink.gif
Сообщение отредактировал 66_ЛЁХА_99 - 20.3.2007, 3:19
Bent
сообщение 20.3.2007, 5:39
MoTo Marvellous
Пользователь №: 63 874
Собственно, считаю лучшим модом был 0.2 Final, остальные 0.3 и теперь уже 0.4 черезчур навороченные и по моему убеждению половину функций, если не больше вообще не нужно...
79R проигрышный вариант, большинство пользователей не будет ставить мод 0.4, максимум поставят и откатятся.
P.S. Хотя уже с полгода пользуюсь стандартной 49R подредактированной под себя и меня всё устраивает...
Сообщение отредактировал Bent - 20.3.2007, 5:40
Vadim Velikii
сообщение 20.3.2007, 5:59
Прошивка: 49E.m.
Вот-вот! На 49R мод 0.3 можно было эффект вибрации во время проигрывания музыки включить/выключить, и звук мгновенно менялся, а теперь для этого приходится телефон перезагружать!
И вообще, есть те, кому нравятся 7хRпрошивки, и есть те, кому нравится 4xR.
Мне нравится 49я. Так что присоединяюсь ко всем, кто просит сделать мод на 49R!
Сообщение отредактировал Vadim Velikii - 20.3.2007, 10:52
kemre
сообщение 20.3.2007, 7:25
Пользователь №: 121 096
Прошивка: LP 49R
а если тока рефлеш зашить, будет ли новая "Технология" работать?
Халдей
сообщение 20.3.2007, 7:26
Пользователь №: 42 573
Модель телефона: mpx220
Прошивка: 351 sp2
Мне мод понравился, так как телефон старый я рад хоть что то на него делают новое, несмотря на то что большинство фич я неиспользую
Trentemoller
сообщение 20.3.2007, 9:39
Из: Армавир
Bent,
Полностью тебя поддерживаю, 0.2 мод был самый удачный, в плане качества. В 0.3 были странные глюки с камерой, поставил, посмотрел и откатился сразу же обратно на 0.2. Про 0.4 говорить пока ниче небуду, т.к. это альфа версия еще очень сырая и недоработанная. Чтож будем просить electro, чтобы убирал все стандартные и нестандартные глюки с 0.4 мода или просить сделать его на базе 49r.
_TRANE_
сообщение 20.3.2007, 11:58
MOTOmeloMAN
Из: New_Oskol_City(Бел.Область)
Пользователь №: 104 202
Модель телефона: E398+KOSS The PLUG
Прошивка: MPX 398 DeLuXe
Парни чё вым всем так не нравится 79r раньше я был на 49r (elektro mod 0.3b) но недели 2 назад поставил симбу 79r и чё? АФИГЕЕНННАЯ ПРОША даже если на 79r если вам не нравится что звук тихий то отредактируйте Gain,Param_table через MV и звук по громкости и качеству звучания такой же как и на
49r ,но +анлим видео+скорость.Тем более что elektro сказал, что батарею держит как на 49r!!!
=BazOOka=
сообщение 20.3.2007, 12:20
Прошивка: 4AP
QUOTE(_TRANE_ @ 20.3.2007, 14:58) *
Кому что но 49R хочется! Можно долго спорить и сравнивать эти 2 базы и каждый будет доказывать что одна лучше другой... Вопрос в том будет ли 49 или нет?
HUNTER_ok
сообщение 20.3.2007, 12:26
Из: Заозерный webstream :D
Пользователь №: 106 065
Модель телефона: SE W810i
Я тоже потдерживаю TRANE'а, 79R прошивка во многом рулит, MS RC3 лучший из монстров, который я устанавливал. Tim2005 говорил, что в ней есть новые классы для корелетов. Масса преимуществ. Да ведь новая прошивка должна быть лучше.
Сообщение отредактировал HUNTER_ok - 20.3.2007, 12:26
Valeo
сообщение 20.3.2007, 14:54
Going eternally
Из: Україна. м. Чернігів
Пользователь №: 46 805
Модель телефона: 1
Дата поощрения/наказания
Т.е. мнение автора вас не интересует?
Цитата(elektro255 @ Вчера, 15:13)
не будет 49R, теперь только я буду заниматься 79R (звук дастся сделать)
Сообщение отредактировал Valeo - 20.3.2007, 14:57
=BazOOka=
сообщение 20.3.2007, 16:49
Прошивка: 4AP
Valeo, а вдруг electro255 над нами сжалится и все-таки сделает 49? unsure.gif
San3k
сообщение 20.3.2007, 18:00
Прошился - доволен. Для альфа-версии очень даже ничего. Скорость высокая (особенно с пониженными таймингами), звук отличный. Короче почти всё ОК, жду бету smile.gif
DarkNeo
сообщение 20.3.2007, 20:09
всё же....что делать с этим:
Elektro255 V0.4 alpha mod
без GPRS не могу...откатился на v0.3..
Мачо
сообщение 21.3.2007, 7:58
Из: Киров
Пользователь №: 8 569
Прошивка: Dream A Reality 2.0
Попробуйте залить сертификаты от T_mobile может пойдёт gprs
gunghost
сообщение 21.3.2007, 12:27
Пользователь №: 71 735
Прошивка: Всегда самая лудшая
Это как?
v_leon
сообщение 21.3.2007, 12:31
МотоДизайнер
Из: Россия, Бийск
Пользователь №: 47 326
Модель телефона: e398 v3i v220 vtW740
Прошивка: mpx
Медиавьювер отказался восстанавливать справочник. Сказал, что файл бэкапа отсутствует. Попробовал раскидать бэкап во все места, где он (теоретически может находится) не помогло. Без справочника как-то грустно стало. Когда еще и ЖПРС не захотел работать я еще раз с тоской прошелся по новому меню, попереключал фичи и откатился на v 0.2... Буду ждать стабильной версии... Хотелось бы таки на 49r... sad.gif
А в целом, фичи интересные и уместные.
PS может кто-нибудь шапку поправит? Electro похоже не до этого...
_TRANE_
сообщение 21.3.2007, 14:32
MOTOmeloMAN
А когда примерно выйдет BETA ?
=BazOOka=
сообщение 21.3.2007, 15:07
Прошивка: 4AP
QUOTE(_TRANE_ @ 21.3.2007, 17:32) *
Ну в первом же посте написано:
QUOTE
Никто кроме electro255 не знает (а может и он тоже не знает)! Если не терпится знать, пиши в личку.
_26_
сообщение 21.3.2007, 19:06
Пользователь №: 90 123
Модель телефона: E 398
Прошивка: Electro255_mod_v_0.2
установи МВ с сайта - все будет нормально работать.
Без инета плохо - откатываюсь
screamer2k
сообщение 21.3.2007, 19:54
Пользователь №: 62 070
Модель телефона: L7e
Прошивка: без RSA
да... что инета нет это жестоко... кстати, сегодня нашёл такие глюки - проверьте, есть ли у кого. попробуйте поменять Базовые клавиши - вверх-вниз-влево-вправо. телефон 4 раза уходил в перезагрузку. в чём проблема-не пойму. потом, когда мне удалось всё настроить, телефон САМ ИХ СБРОСИЛ! thumbdown.gif
=BazOOka=
сообщение 21.3.2007, 20:03
Прошивка: 4AP
screamer2k, глюк с базовыми клавишами у кого-то тоже был:
QUOTE
Сообщение отредактировал bazooka47 - 21.3.2007, 20:04
сильвер398
сообщение 21.3.2007, 22:06
Из: Донецк
Пользователь №: 114 125
Модель телефона: Nokia 5700
поддерживаю всех кто за 49R!последний симбиан-супер,несмотря на глюки!звук на ней даж лучше чем на49R!но вот батарея меня просто достала-откатился на 49R electro255!этот мод качать пока не стану-без инета ну никак не могу как и все остальные мотофановцы!
linxun
сообщение 22.3.2007, 1:22
Пользователь №: 108 892
Модель телефона: MOTO V3I
Прошивка: R47A_G_08_D9.3DR
elektro255
Menu "Engineering" to Chinese?
Текстовая версия Сейчас: 26.7.2025, 2:15
