23 страниц V « < 15 16 17 18 > »
Elektro255 V0.4 alpha 4 mod (4xR), 44R,46R,49R,79R
elektro255
сообщение 23.9.2006, 12:06 Закрепленное сообщение!
Из: Poland, Siedlce
Пользователь №: 53 130
09-04-2007
V0.4a4 Alpha: http://elektro255.ovh.org
08-04-2007
V0.4a3 Alpha: http://elektro255.ovh.org
07-04-2007
V0.4a2 44R Alpha: http://elektro255.ovh.org
20-12-2006
V0.3 79R Final mod: http://elektro255.ovh.org
27-11-2006
v0.3 for 49R Final mod http://elektro255.ovh.org/
26-11-2006
V0.3 46R Final mod: http://elektro255.ovh.org
НА Е1 Rokr с бутом 0А02 (оригинальный) НЕ ПОСТАВИТЕ БЕЗ Т.П.!
V0.4 alpha 4
Changes:
- Fixed problem with display timeout (fullscreen clock) when SMS/CALL received
Features:
- 4xR and 7xR MIX (use with 4xR flex)
- unlimited Video recording
- keypad automatic lock
- low battery alarm can be turned off or depend on ring style.
- Scheduled Ring Styles (ring style and funlight style can change automatically on given time and week day)
- flashlight shortcut (##)
- extra menu (shortcut *1 [shortcut is only for testing later will be changed])
- automatic menu enter, without sim card (emergency calls working too)
- new Java methods
- settings are stored on files
- no simlock checking
- Volume-bar sound can be turned off
- multiple menus (every skin can have one mma_ucp)
- Ported patches:
o SMS report significantly turned ON
o more folders in OBEX via BT
o removed unused folders from TransFlash
o Java have access to system files
o increased iTap user dictionary size
o no delete incall on SIM replace
o Bluetooth time changed to 3 minutes
o reordered camera store menu (store only is first)
o SMS alert is using default ringtone
OLD versions(V0.1-0.3):
Firmware changes:
- firmware based on 46R from StarterXP MP
- FULL SW access from Java
- LUMA&CHROMA tables moved to memory - now you can change JPEG compresion from Java
- StarterXP flex
- added dualboot
Flasher changes:
- if you have PDS_4013 flasher will no recreate this
Personalization tool changes:
- first version for 0.3_46R SW mod
- changing splash screen
- changing font (you can use *.fnt or *.smg CG4 files)
- you can turn on, turn off menu access without sim cart
- changing my shortcuts
Новая версия V0.4 alpha 4
Изменения:
- Устранена проблема с таймаутом дисплея(полноэкранные часы) при приеме смс/звонка
Новое:
- Прошивка создана как микс 4xR и 7xR (флекс 4xR ) В 44R она переименована для совместимости! Она близко не лежит к 44R на самом деле!
- Безлимитная запись видео (64мб макс как в 6х7х)
- Автоблок клавиатуры
- Звук разряженой батареи можно выключать или задать стилем оповещения(?).
- Расписание стилей оповещения (стиль оповещения и фанлайтмогут менятся автоматически по времени и дням недели)
- Фонарик по (##)
- Дополнительное меню (метка *1 [только для теста, после может изменится])
- Автоматический вход в меню без сим-карты (аварийные звонки работают)
- Новые методы в Яве (не от 79R, а новые)
- Настройки хранятся в файлах
- Не проверяется лоченость ПДС на симку (работает с лоченым пдс)
- Звук изменения громкости можно отключить
- Мультименю (каждый скин может иметь собственный мма_уцп)
- Портированы патчи:
o Оповещение о доставке SMS всегда вкл.
o больше папок доступно по OBEX из блютуза
o удалены неиспользуемые папки с флешки
o Полный доступ к системным файлам из явы
o увеличен размер пользовательского словаря iTap
o не удалыются последние вызовы при смене сим
o Время обнаружения блютуза - 3 минуты
o Меню сохранения видеозаписи (просто сохранить - первым пунктом)
o при приходе SMS играет "мелодия на смс", а не установленная на этого пользователя
Для версий 0.1-0.3
Изменения в прошивке:
- Создана на базе монстра StarterXP 46R
- Полный доступ к прошивке (симы, озу) из явы
- Таблицы сжатия фотографий перенесены в озу - теперь из явы можно управлять качеством фотографий (сжатием)
- флекс StarterXP
- добавлен дуалбут
Изменения флешера:
-Если ПДС версии 4013 (373 платформа), ПДС не пересоздается.
Изменения персонализации (Personalization tool):
- впервые для мода использована 46 прошивка
- замена заставки (на включение?)
- замена шрифта (лангпак, CG4)
- можно вкл. и выкл. доступ к меню без сим-карты
- изменен ярлык (копирайт?)
Для работы Personalization tool требуется положить в папку программы несжатый бинарный бэкап (32 мегабайта) под именем SW.bin
Прекращаем флудить, типа а когда выйдет новая версия, и.т.д.и.т.п, или придётся наказывать!
тему почистил, архив по 1 декабря тут:
Прикрепленный файл MotoFan_ru_electro.zip   ( 66.56 килобайт ) Кол-во скачиваний: 3902
Сообщение отредактировал elektro255 - 9.4.2007, 12:21
Jumperrr
сообщение 9.4.2007, 15:23
Пользователь №: 91 740
Модель телефона: E398 => Е1 iTunes
Прошивка: R373.....ххR
Супер!!! clap.gif У меня нету слов!!! Как хорошо что с нами electro smile.gif
yurybol
сообщение 9.4.2007, 15:26
Из: Ростовская область.
Пользователь №: 12 235
Прошивка: Надеюсь поменять
SharkExE, я немного не понял. То есть разрыв идет если активности нет? Так?
А если подключен mIRC клиент и идет постоянная связь/активность то разрыв быть не должен?
У меня как раз-таки разрывается при АКТИВНОЙ связи. sad.gif Обидно
ЗЫ. На других прошивках такого нету, только на 1 и 2 альфах
Сообщение отредактировал yurybol - 9.4.2007, 15:29
Beaumont
сообщение 9.4.2007, 15:39
Миротворец
Из: г. Москва
Пользователь №: 39 110
Прошивка: R373_G_0E.30.79R
Вопрос: работает ли ритм-подсветка? И какие значения можно установить в выборе времени?
Да, и ещё, кто-нибудь ставил на флекс от 1.5 симбы?
Сообщение отредактировал Beaumont - 9.4.2007, 15:55
San3k
сообщение 9.4.2007, 15:42
Пользователь №: 108 480
Модель телефона: Nokia 5310; E398
Цитата(Slavasiv @ 9.4.2007, 18:11) *
Добавлено позже (9.4.2007, 18:21):
Видео бесконесное не пишет на моде о.4 альфе4 максимум у меня 2,5 минуты
У меня видео анлим...
=BazOOka=
сообщение 9.4.2007, 15:47
Пользователь №: 107 478
Модель телефона: rokr e2
Прошивка: 4AP
Видео:elektro255 уже написал, что если анлимитное видео не работает, то пробуйте другой флекс или 004E SEEM!
Side
сообщение 9.4.2007, 15:59
Из: Мурманск
Пользователь №: 81 705
Модель телефона: V535, EM30
Цитата(Trentemoller @ 9.4.2007, 19:17) *
Я так понял, первый будет патч для передачи ява через мультимедиа, а второй на автоматическую блокировку клавиатуры!? unsure.gif
Не правильно ты понял, вторым будет патч изменяющий комбинацию кнопок для ручной блокировки разблокировки клавиатуры.
Сообщение отредактировал Side - 9.4.2007, 16:00
San3k
сообщение 9.4.2007, 16:04
elektro255, why you change SW Version in every new version of your mod? a2-44R, a3-49R, a4-46R...
=BazOOka=
сообщение 9.4.2007, 16:07
Прошивка: 4AP
San3k, это для совместимости с прогами. На самом деле все эти прошивки не 44R, не 46R, не 46R, а MIX, то есть смесь из прошивок 4хR и 7xR.
VkD
сообщение 9.4.2007, 16:27
Пользователь №: 64 617
Прошивка: MS 1.5b
elektro255,
Please add correct 'Save embedded file from MMS' feature in your next mods is it's possible smile.gif
novis
сообщение 9.4.2007, 16:49
Из: г.Ижевск
Пользователь №: 76 691
Прошивка: 79r
для расширенного itap нужен и словарь расширенный (iTAP_User_Dictionary). на последней альфе с этим как? какой размер файла и что за содержимое у него?
Timik
сообщение 9.4.2007, 17:06
Пользователь №: 100 902
Прошивка: даже не знаю теперь
novis,
на а4 iTap такой же как на а2 и а3.. только что проверил, а вот как это исправить.. никто не говорит
Добавлено позже (9.4.2007, 21:09):
И еще баланс проверять стало неудобно, меню включается..
elektro255
сообщение 9.4.2007, 17:12
Из: Poland, Siedlce
iTap changed to 6500 bytes
Сообщение отредактировал elektro255 - 9.4.2007, 17:12
San3k
я знаю, но почему он меняет версии, я это хотел узнать...
Prometeius
сообщение 9.4.2007, 17:19
Пользователь №: 121 989
Модель телефона: V360
Прошивка: ACR
Нашел баг. Когда нажимаешь на режим Авиа трубка перезагружается. Проверьте кто нибудь.
SAM398
сообщение 9.4.2007, 17:35
Пользователь №: 93 560
Модель телефона: Nokia 6681
На прошу electro255 49r v02 нормально станет v04a4 ? Как я понял, прошивать поверх нее. Ленг который сейчас установлен не затрется?
deadmoto
сообщение 9.4.2007, 17:47
Главный Новостник
Из: Омск
Пользователь №: 49 284
Модель телефона: Motorola
Прошивка: Motorola Original
SAM398, встаёт на любую прошу с 4х флексом!
kemre
сообщение 9.4.2007, 18:04
Пользователь №: 121 096
Прошивка: LP 49R
а если патч применить который меняет *1 на другую комбинацию? как потом вызвать меню то это?
Trentemoller
сообщение 9.4.2007, 18:33
Из: Армавир
Пользователь №: 105 953
Прошивка: R373_G_0E.30.49R
elektro255,
Bugs:
1. When press on a mode Avia the telephone is reloaded!
2. Slowly works animation, unpleasant bug!
With mod the large thanks, is simple super thumbsup.gif !
Сообщение отредактировал Trentemoller - 9.4.2007, 18:40
Timik
сообщение 9.4.2007, 18:35
SAM398,
Затрется, я на v0.3 ставил.. с iTap такие же глюки, хотя до установки все было нормально..
X3M-pro
сообщение 9.4.2007, 18:38
Пользователь №: 95 971
Модель телефона: E398 +512Mb
Цитата(=BazOOka= @ 9.4.2007, 14:18) *
Для тех кто в танке. Насчет патчей:
"Мультиструктура меню" - у каждого скина - свой mma_ucp.
Как это работает объясни пожалуйста!!!
Vitek2
сообщение 9.4.2007, 18:51
Пользователь №: 64 041
Прошивка: 42r + MOTOsimbian 1.2
zolookas
Пользователь №: 43 073
QUOTE(X3M-pro @ 10.4.2007, 7:38) *
IPB Image
Vitek2
сообщение 9.4.2007, 18:52
elektro255
сообщение 9.4.2007, 19:05
Из: Poland, Siedlce
you mean plane mode ? it is working on my moto
Timik
сообщение 9.4.2007, 19:10
Цитата(Vitek2 @ 9.4.2007, 22:52) *
делаешь бекап, переименовываешь его в SW.bin, закидываешь в папку Personalization tool и запускаешь программу
Trentemoller
сообщение 9.4.2007, 19:26
Из: Армавир
elektro255,
Thanks, Why that at once has not earned airpln mode!
And please, if you will not complicate make patch on installation skins in a disk /a/mobile/skins
I shall be very grateful. Itself make I can not, because it is impossible open update.bin as cg1 shuffle.gif
elektro255
elektro255
elektro255
Very Very Very Big Thanks for patch in skins on disc /a/. Sorry, 1 + put I can not, would put still:)
Сообщение отредактировал Trentemoller - 9.4.2007, 19:50
elektro255
сообщение 9.4.2007, 19:47
Из: Poland, Siedlce
BT patch fixed and /a/mobile/skins patch added http://elektro255.ovh.org/
Side
сообщение 9.4.2007, 20:11
Из: Мурманск
По поводу словаря, elektro255 пишет что он увеличил размер пользовательского словаря.
Если вы прошиваете без флекса то для того чтобы это заработало нужно удалить старый файл (/a/iTAP_User_Dictionary) и перезагрузить телефон. Возможно проблемы с "глупым" iTap из-за этого.
После этой операции телефон естественно забудет слова которые вы ввели вручную, поэтому рекомендую попробовать воспользоваться программой iTAP Dictionary Editor чтобы сохранить а потом восстановить словарь, вроде она это умеет (все вопросы в топик программы)
Trentemoller
сообщение 9.4.2007, 20:13
Из: Армавир
Все вроде устраивает, все супер круто, только вот что делать с анимацией, уж очень медленная она, ооочень медленная. С моим скином в меню очень медленно выплывает sad.gif
Думаю elektro исправит этот баг.
All like arranges, all super is abrupt, only what to do(make) with animation, very slow she, very slow. With mine skins in the menu very slowly comes up: (
I think elektro will correct this bugs.
And strange crackling at movement till the menu! Very much ненравится, it is very unpleasant!:unsure:
Сообщение отредактировал Trentemoller - 9.4.2007, 20:19
SerJiuS
сообщение 9.4.2007, 20:33
Пользователь №: 67 508
После патча комбинация клавишь для вызова меню меняется на -> *#
Наконец-то начало сохранять вложения в ММС smile.gif Только пункта меню нету чтобы можно было просто сохранить sad.gif Изображения сохранял после выбора пункта меню "Применить как фон" или заставку!
Подскажите как можно добавить пункт меню. Если нужен патч сообщите пожалуйста elektro255.
=BazOOka=
сообщение 9.4.2007, 21:03
Прошивка: 4AP
Trentemoller,
QUOTE(elektro255 @ Yesterday, 19:08)
animation speed depend on DRM speed table (use this tool: http://www.e398mod.com/content/view/482/28/ ), or wait for somebody who will made full monster on my software
"Скорость анимации зависит от таймингов ДРМ. Используй прогу MotoSpeed" (ссылку дал elektro255) А вот её тема на мотофане: Переключаем Скоростя в Телефоне на Повышенные ! Motospeed
Trentemoller
сообщение 9.4.2007, 21:18
Из: Армавир
=BazOOka=,
Я не новечек, и сделал себе тайминги сразу, как вышла прога. У меня на 0.2 49r моде анимация в меню была очень быстрой, при прошивки на 0.4 alpha 4 она стала очень медленной, практически 1 кадр в секунду. Пробывал заливать измененный дрм по новой, безуспешно. По мне точным кажется, что в последнем моде анимация зависит не от таймингов! Это скорее недоработка прошивки! Вспомни альфа мод на 79r, аналогично и некакие тайминги роли неиграли. Вообще и на 49r без редактирования таймингов анимация летала! Это же микс прошивок версии 4х и 7х, некоторые баги, типа анимации с 7х остались, а с 4х потрескивание клавы при перемещении по меню.
Заметьте особенность, при прослушивании музыки и одновременно перемещению по меню, исчезли глюки. Теперь при перемещении с музыкой по меню все летает, как на L7, V3i и подобных!!! smile.gif
И вот еще что, добавил оффсеты от elektro дня 0.4 мода на бутскрин [ROKR E1 R373...0.4] Hellomoto=0x00844284. Вроде прописал все правильно, но при
попытки применить патч вылазиет вот такая ошибка 0x00844284 is not a valid integer value
Что это значит?
Откатываюсь пока на 0.2 49r, т.к. с глюками анимации и озвучкой клавиатуры сидеть очень неохото!!! sad.gif
Сообщение отредактировал Trentemoller - 9.4.2007, 22:30
deadmoto
сообщение 10.4.2007, 2:30
Главный Новостник
Из: Омск
Trentemoller,
Что это значит?
Странно...У мну всё на ура сделалось...Какой ФБ пользовал?
elektro255, you told that iTAP Dictionary size is 6500b on one of the last pages, but its really size is about 34kb so iTAP DE is not working with it, it's strange)))
It's strange because DE can read dictionary, but when i fill it from statistics and write it to my phone (sizes of dictionary is right) phone empty it '(
Сообщение отредактировал deadmoto - 10.4.2007, 7:37
elektro255
сообщение 10.4.2007, 8:17
Из: Poland, Siedlce
can anybody send me skin what working very slow ? because i can't find this slow animations
Добавлено позже (10.4.2007, 10:31):
to diable this edit seem WAV_UI_AVAILABLE SEEM 0032 byte 0x82 bit 6
Trentemoller
сообщение 10.4.2007, 8:40
Из: Армавир
elektro255,
Here this skin. On 49 fashion to the menu simply flied and without everyones motospeed. In mix mod it very slow, even with motospeed. Probably not in motospeed business, this in SW!
Сообщение отредактировал Trentemoller - 10.4.2007, 8:43
elektro255
сообщение 10.4.2007, 9:06
Из: Poland, Siedlce
Цитата(Trentemoller @ 10.4.2007, 10:40) *
elektro255,
on my moto this skin working normal, so we need to find what is responsible for that, maybe try my SEEM
P.S. I made personalization tool to change splash screen and language in my menu
Сообщение отредактировал elektro255 - 10.4.2007, 9:07
-mak-
сообщение 10.4.2007, 9:12
Из: Город-герой Волгоград
Пользователь №: 56 604
Модель телефона: qtek s200
Electro255, Can you upload your sw as fullflash in next version
elektro255
сообщение 10.4.2007, 9:19
Из: Poland, Siedlce
my easter break is ending ( i have exams in next week) smile.gif so for next version we need wait for long time smile.gif
Trentemoller
сообщение 10.4.2007, 10:04
Из: Армавир
elektro255,
All the same animation slowly works, seem not help. Elektro try to stitch the original 49, and then mix and увидешь a difference in animation. On 49 originals she in 2 times will be faster.
It is sole lack. It is possible already to get used to a sound of the keyboard
Все равно анимация медленно работает, симы непомогают. Elektro попробуй прошить оригинал 49, а потом свой mix и увидешь разницу в анимации. На 49 оригинал она будет в 2 раза быстрее.
Это единственный недостаток, к звуку клавиатуры можно уже привыкнуть
Сообщение отредактировал Trentemoller - 10.4.2007, 10:04
Side
сообщение 10.4.2007, 10:52
Из: Мурманск
Вот это пробовал ?:
Сообщение отредактировал Side - 10.4.2007, 10:53
Текстовая версия Сейчас: 22.7.2025, 22:54
