23 страниц V « < 16 17 18 19 > »
Elektro255 V0.4 alpha 4 mod (4xR), 44R,46R,49R,79R
elektro255
сообщение 23.9.2006, 12:06 Закрепленное сообщение!
Из: Poland, Siedlce
Пользователь №: 53 130
09-04-2007
V0.4a4 Alpha: http://elektro255.ovh.org
08-04-2007
V0.4a3 Alpha: http://elektro255.ovh.org
07-04-2007
V0.4a2 44R Alpha: http://elektro255.ovh.org
20-12-2006
V0.3 79R Final mod: http://elektro255.ovh.org
27-11-2006
v0.3 for 49R Final mod http://elektro255.ovh.org/
26-11-2006
V0.3 46R Final mod: http://elektro255.ovh.org
НА Е1 Rokr с бутом 0А02 (оригинальный) НЕ ПОСТАВИТЕ БЕЗ Т.П.!
V0.4 alpha 4
Changes:
- Fixed problem with display timeout (fullscreen clock) when SMS/CALL received
Features:
- 4xR and 7xR MIX (use with 4xR flex)
- unlimited Video recording
- keypad automatic lock
- low battery alarm can be turned off or depend on ring style.
- Scheduled Ring Styles (ring style and funlight style can change automatically on given time and week day)
- flashlight shortcut (##)
- extra menu (shortcut *1 [shortcut is only for testing later will be changed])
- automatic menu enter, without sim card (emergency calls working too)
- new Java methods
- settings are stored on files
- no simlock checking
- Volume-bar sound can be turned off
- multiple menus (every skin can have one mma_ucp)
- Ported patches:
o SMS report significantly turned ON
o more folders in OBEX via BT
o removed unused folders from TransFlash
o Java have access to system files
o increased iTap user dictionary size
o no delete incall on SIM replace
o Bluetooth time changed to 3 minutes
o reordered camera store menu (store only is first)
o SMS alert is using default ringtone
OLD versions(V0.1-0.3):
Firmware changes:
- firmware based on 46R from StarterXP MP
- FULL SW access from Java
- LUMA&CHROMA tables moved to memory - now you can change JPEG compresion from Java
- StarterXP flex
- added dualboot
Flasher changes:
- if you have PDS_4013 flasher will no recreate this
Personalization tool changes:
- first version for 0.3_46R SW mod
- changing splash screen
- changing font (you can use *.fnt or *.smg CG4 files)
- you can turn on, turn off menu access without sim cart
- changing my shortcuts
Новая версия V0.4 alpha 4
Изменения:
- Устранена проблема с таймаутом дисплея(полноэкранные часы) при приеме смс/звонка
Новое:
- Прошивка создана как микс 4xR и 7xR (флекс 4xR ) В 44R она переименована для совместимости! Она близко не лежит к 44R на самом деле!
- Безлимитная запись видео (64мб макс как в 6х7х)
- Автоблок клавиатуры
- Звук разряженой батареи можно выключать или задать стилем оповещения(?).
- Расписание стилей оповещения (стиль оповещения и фанлайтмогут менятся автоматически по времени и дням недели)
- Фонарик по (##)
- Дополнительное меню (метка *1 [только для теста, после может изменится])
- Автоматический вход в меню без сим-карты (аварийные звонки работают)
- Новые методы в Яве (не от 79R, а новые)
- Настройки хранятся в файлах
- Не проверяется лоченость ПДС на симку (работает с лоченым пдс)
- Звук изменения громкости можно отключить
- Мультименю (каждый скин может иметь собственный мма_уцп)
- Портированы патчи:
o Оповещение о доставке SMS всегда вкл.
o больше папок доступно по OBEX из блютуза
o удалены неиспользуемые папки с флешки
o Полный доступ к системным файлам из явы
o увеличен размер пользовательского словаря iTap
o не удалыются последние вызовы при смене сим
o Время обнаружения блютуза - 3 минуты
o Меню сохранения видеозаписи (просто сохранить - первым пунктом)
o при приходе SMS играет "мелодия на смс", а не установленная на этого пользователя
Для версий 0.1-0.3
Изменения в прошивке:
- Создана на базе монстра StarterXP 46R
- Полный доступ к прошивке (симы, озу) из явы
- Таблицы сжатия фотографий перенесены в озу - теперь из явы можно управлять качеством фотографий (сжатием)
- флекс StarterXP
- добавлен дуалбут
Изменения флешера:
-Если ПДС версии 4013 (373 платформа), ПДС не пересоздается.
Изменения персонализации (Personalization tool):
- впервые для мода использована 46 прошивка
- замена заставки (на включение?)
- замена шрифта (лангпак, CG4)
- можно вкл. и выкл. доступ к меню без сим-карты
- изменен ярлык (копирайт?)
Для работы Personalization tool требуется положить в папку программы несжатый бинарный бэкап (32 мегабайта) под именем SW.bin
Прекращаем флудить, типа а когда выйдет новая версия, и.т.д.и.т.п, или придётся наказывать!
тему почистил, архив по 1 декабря тут:
Прикрепленный файл MotoFan_ru_electro.zip   ( 66.56 килобайт ) Кол-во скачиваний: 3902
Сообщение отредактировал elektro255 - 9.4.2007, 12:21
deadmoto
сообщение 9.4.2007, 17:47
Главный Новостник
Из: Омск
Пользователь №: 49 284
Модель телефона: Motorola
Прошивка: Motorola Original
SAM398, встаёт на любую прошу с 4х флексом!
kemre
сообщение 9.4.2007, 18:04
Пользователь №: 121 096
Прошивка: LP 49R
а если патч применить который меняет *1 на другую комбинацию? как потом вызвать меню то это?
Trentemoller
сообщение 9.4.2007, 18:33
Из: Армавир
Пользователь №: 105 953
Прошивка: R373_G_0E.30.49R
elektro255,
Bugs:
1. When press on a mode Avia the telephone is reloaded!
2. Slowly works animation, unpleasant bug!
With mod the large thanks, is simple super thumbsup.gif !
Сообщение отредактировал Trentemoller - 9.4.2007, 18:40
Timik
сообщение 9.4.2007, 18:35
Пользователь №: 100 902
Прошивка: даже не знаю теперь
SAM398,
Затрется, я на v0.3 ставил.. с iTap такие же глюки, хотя до установки все было нормально..
X3M-pro
сообщение 9.4.2007, 18:38
Пользователь №: 95 971
Модель телефона: E398 +512Mb
Цитата(=BazOOka= @ 9.4.2007, 14:18) *
Для тех кто в танке. Насчет патчей:
"Мультиструктура меню" - у каждого скина - свой mma_ucp.
Как это работает объясни пожалуйста!!!
Vitek2
сообщение 9.4.2007, 18:51
Пользователь №: 64 041
Прошивка: 42r + MOTOsimbian 1.2
zolookas
Пользователь №: 43 073
QUOTE(X3M-pro @ 10.4.2007, 7:38) *
IPB Image
Vitek2
сообщение 9.4.2007, 18:52
elektro255
сообщение 9.4.2007, 19:05
Из: Poland, Siedlce
you mean plane mode ? it is working on my moto
Timik
сообщение 9.4.2007, 19:10
Цитата(Vitek2 @ 9.4.2007, 22:52) *
делаешь бекап, переименовываешь его в SW.bin, закидываешь в папку Personalization tool и запускаешь программу
Trentemoller
сообщение 9.4.2007, 19:26
Из: Армавир
elektro255,
Thanks, Why that at once has not earned airpln mode!
And please, if you will not complicate make patch on installation skins in a disk /a/mobile/skins
I shall be very grateful. Itself make I can not, because it is impossible open update.bin as cg1 shuffle.gif
elektro255
elektro255
elektro255
Very Very Very Big Thanks for patch in skins on disc /a/. Sorry, 1 + put I can not, would put still:)
Сообщение отредактировал Trentemoller - 9.4.2007, 19:50
elektro255
сообщение 9.4.2007, 19:47
Из: Poland, Siedlce
BT patch fixed and /a/mobile/skins patch added http://elektro255.ovh.org/
Side
сообщение 9.4.2007, 20:11
Из: Мурманск
Пользователь №: 81 705
Модель телефона: V535, EM30
По поводу словаря, elektro255 пишет что он увеличил размер пользовательского словаря.
Если вы прошиваете без флекса то для того чтобы это заработало нужно удалить старый файл (/a/iTAP_User_Dictionary) и перезагрузить телефон. Возможно проблемы с "глупым" iTap из-за этого.
После этой операции телефон естественно забудет слова которые вы ввели вручную, поэтому рекомендую попробовать воспользоваться программой iTAP Dictionary Editor чтобы сохранить а потом восстановить словарь, вроде она это умеет (все вопросы в топик программы)
Trentemoller
сообщение 9.4.2007, 20:13
Из: Армавир
Все вроде устраивает, все супер круто, только вот что делать с анимацией, уж очень медленная она, ооочень медленная. С моим скином в меню очень медленно выплывает sad.gif
Думаю elektro исправит этот баг.
All like arranges, all super is abrupt, only what to do(make) with animation, very slow she, very slow. With mine skins in the menu very slowly comes up: (
I think elektro will correct this bugs.
And strange crackling at movement till the menu! Very much ненравится, it is very unpleasant!:unsure:
Сообщение отредактировал Trentemoller - 9.4.2007, 20:19
SerJiuS
сообщение 9.4.2007, 20:33
Пользователь №: 67 508
После патча комбинация клавишь для вызова меню меняется на -> *#
Наконец-то начало сохранять вложения в ММС smile.gif Только пункта меню нету чтобы можно было просто сохранить sad.gif Изображения сохранял после выбора пункта меню "Применить как фон" или заставку!
Подскажите как можно добавить пункт меню. Если нужен патч сообщите пожалуйста elektro255.
=BazOOka=
сообщение 9.4.2007, 21:03
Пользователь №: 107 478
Модель телефона: rokr e2
Прошивка: 4AP
Trentemoller,
QUOTE(elektro255 @ Yesterday, 19:08)
animation speed depend on DRM speed table (use this tool: http://www.e398mod.com/content/view/482/28/ ), or wait for somebody who will made full monster on my software
"Скорость анимации зависит от таймингов ДРМ. Используй прогу MotoSpeed" (ссылку дал elektro255) А вот её тема на мотофане: Переключаем Скоростя в Телефоне на Повышенные ! Motospeed
Trentemoller
сообщение 9.4.2007, 21:18
Из: Армавир
=BazOOka=,
Я не новечек, и сделал себе тайминги сразу, как вышла прога. У меня на 0.2 49r моде анимация в меню была очень быстрой, при прошивки на 0.4 alpha 4 она стала очень медленной, практически 1 кадр в секунду. Пробывал заливать измененный дрм по новой, безуспешно. По мне точным кажется, что в последнем моде анимация зависит не от таймингов! Это скорее недоработка прошивки! Вспомни альфа мод на 79r, аналогично и некакие тайминги роли неиграли. Вообще и на 49r без редактирования таймингов анимация летала! Это же микс прошивок версии 4х и 7х, некоторые баги, типа анимации с 7х остались, а с 4х потрескивание клавы при перемещении по меню.
Заметьте особенность, при прослушивании музыки и одновременно перемещению по меню, исчезли глюки. Теперь при перемещении с музыкой по меню все летает, как на L7, V3i и подобных!!! smile.gif
И вот еще что, добавил оффсеты от elektro дня 0.4 мода на бутскрин [ROKR E1 R373...0.4] Hellomoto=0x00844284. Вроде прописал все правильно, но при
попытки применить патч вылазиет вот такая ошибка 0x00844284 is not a valid integer value
Что это значит?
Откатываюсь пока на 0.2 49r, т.к. с глюками анимации и озвучкой клавиатуры сидеть очень неохото!!! sad.gif
Сообщение отредактировал Trentemoller - 9.4.2007, 22:30
deadmoto
сообщение 10.4.2007, 2:30
Главный Новостник
Из: Омск
Trentemoller,
Что это значит?
Странно...У мну всё на ура сделалось...Какой ФБ пользовал?
elektro255, you told that iTAP Dictionary size is 6500b on one of the last pages, but its really size is about 34kb so iTAP DE is not working with it, it's strange)))
It's strange because DE can read dictionary, but when i fill it from statistics and write it to my phone (sizes of dictionary is right) phone empty it '(
Сообщение отредактировал deadmoto - 10.4.2007, 7:37
elektro255
сообщение 10.4.2007, 8:17
Из: Poland, Siedlce
can anybody send me skin what working very slow ? because i can't find this slow animations
Добавлено позже (10.4.2007, 10:31):
to diable this edit seem WAV_UI_AVAILABLE SEEM 0032 byte 0x82 bit 6
Trentemoller
сообщение 10.4.2007, 8:40
Из: Армавир
elektro255,
Here this skin. On 49 fashion to the menu simply flied and without everyones motospeed. In mix mod it very slow, even with motospeed. Probably not in motospeed business, this in SW!
Сообщение отредактировал Trentemoller - 10.4.2007, 8:43
elektro255
сообщение 10.4.2007, 9:06
Из: Poland, Siedlce
Цитата(Trentemoller @ 10.4.2007, 10:40) *
elektro255,
on my moto this skin working normal, so we need to find what is responsible for that, maybe try my SEEM
P.S. I made personalization tool to change splash screen and language in my menu
Сообщение отредактировал elektro255 - 10.4.2007, 9:07
-mak-
сообщение 10.4.2007, 9:12
Из: Город-герой Волгоград
Пользователь №: 56 604
Модель телефона: qtek s200
Electro255, Can you upload your sw as fullflash in next version
elektro255
сообщение 10.4.2007, 9:19
Из: Poland, Siedlce
my easter break is ending ( i have exams in next week) smile.gif so for next version we need wait for long time smile.gif
Trentemoller
сообщение 10.4.2007, 10:04
Из: Армавир
elektro255,
All the same animation slowly works, seem not help. Elektro try to stitch the original 49, and then mix and увидешь a difference in animation. On 49 originals she in 2 times will be faster.
It is sole lack. It is possible already to get used to a sound of the keyboard
Все равно анимация медленно работает, симы непомогают. Elektro попробуй прошить оригинал 49, а потом свой mix и увидешь разницу в анимации. На 49 оригинал она будет в 2 раза быстрее.
Это единственный недостаток, к звуку клавиатуры можно уже привыкнуть
Сообщение отредактировал Trentemoller - 10.4.2007, 10:04
Side
сообщение 10.4.2007, 10:52
Из: Мурманск
Вот это пробовал ?:
Сообщение отредактировал Side - 10.4.2007, 10:53
-mak-
сообщение 10.4.2007, 11:02
Цитата(elektro255 @ Сегодня, 12:19)
my easter break is ending ( i have exams in next week) so for next version we need wait for long time
so, can you upload your flex ? or your backup
sadface
сообщение 10.4.2007, 11:47
Пользователь №: 110 110
Модель телефона: Z6 + Kingston 2GB
Прошивка: 44R + PE
elektro255,
Bug - When telephone used as modem(gprs) for pc he is reloaded inadvertently.
Sorry for my very bad english
Баг - когда телефон используется как GPRS модем он самопроизвольно перегружается время от времени.
Пока вернулся на мод v0.3
X3M-pro
сообщение 10.4.2007, 14:40
Я так понял, что после этого патча можно, кидать например mma_ucp0, mma_ucp1, mma_ucp0 и тд. И они будут заменятся при смене скина. Я прав????
sadface
сообщение 10.4.2007, 15:02
Прошивка: 44R + PE
Да ты прав. я уже так использую у меня куча полноэкранок стоит и всё отлично работает.
Side
сообщение 10.4.2007, 16:16
Из: Мурманск
Обычно этим термином называется залочка телефона под конкретного оператора (т.н. операторские телефоны)
sadface
сообщение 10.4.2007, 16:50
Прошивка: 44R + PE
Side,
Т.е. прошивка не проверяет ПДС на лоченость. Шьёш и лоченый телефон уже не лоченый =)
lexus2000
сообщение 11.4.2007, 5:28
Пользователь №: 56 309
Подскажите пожалуйста как мне сейчас востановить бекап телефонного справочника, который я снял с помощью P2Ktools v3 с v0.4a1. Сейчас стоит v0.4a4 и программа вроде как востанавливает справочник, но после перезагрузки я не вижу ни одного номера на телефоне? На всех ранее стоящих прошивках у меня востнавливался нормально. Где вообще храниться справочник? в 1 группе что ли..
nekr
сообщение 11.4.2007, 6:51
Пользователь №: 103 477
Прошивка: от всего по маленьку
после прошивки нашлось как минимум три презабавных глюка:
1)не отправляюся смс
2)не находятся по болютузу другие телефоны
3)часто дохнет и прохо загружается
вполне возможн что из-за того что ставилось на GHOST Limited Edition
trips
сообщение 11.4.2007, 7:24
Пользователь №: 52 909
У меня UPDATE.EXE пишет что телефон не подключен! Че такое? Может чем другим прошить можно этот update.bin?
nekr
сообщение 11.4.2007, 7:37
trips, а флешбекап при этом тело видит??
Моя проблема решилась прогитием флекса от R373_49R_&_Art_FleX_6.2
trips
сообщение 11.4.2007, 8:55
Видит. И прошивка Elektro255 V0.4 alpha 2 mod стоит
Сообщение отредактировал trips - 11.4.2007, 9:00
sader
сообщение 11.4.2007, 10:58
Из: Р-ка Карелия, г. Сегежа
Пользователь №: 117 834
Извините за глупый вопрос, но где в V0.4a4 находятся настройки звука разряженной батареи, выключение, перезагрузка телефона и другие функции, изображенные на скринах на сайте elektro255?
Chili89
сообщение 11.4.2007, 11:23
Из: Питер
Пользователь №: 51 289
Модель телефона: E 398
Прошивка: 373 R48
Как воще поставить V0.4a4.
kemre
сообщение 11.4.2007, 11:34
Прошивка: LP 49R
sader,
нажми * и потом 1
nekr
сообщение 11.4.2007, 12:02
Chili89, вырубаешь тело, подрубаешь кабель, переаодишь тело в бут режим
(или как там его #+*+красная кнопка) запускаешь упдате.екзе ждешь надписи коннетид и жмешь апдейт
Текстовая версия Сейчас: 21.7.2025, 22:46
