29 страниц V « < 27 28 29 >
MotoRAZR2 V8, Обсуждение
malek79
сообщение 20.6.2023, 15:27
Пользователь №: 254 009
Модель телефона: Razr² V8
EX,
Unfortunately I didn't even know that this forum was still online back then or that it would be that difficult sad.gif.
I tried several Unlocking services but they can't seem to find the IMEI in the unlocking database. Only 1 service is still looking for possible codes. If that fails, I will just sell it and buy a new one.
сообщение 20.6.2023, 17:54
malek79,
You can buy a used phone in poor condition (with broken flex cable or a broken screen) and swap the main boards.
malek79
сообщение 21.6.2023, 15:26
EXL,
I already sold the defective phone and I plan to replace it with the luxury edition one.
сообщение 21.6.2023, 17:14
malek79,
Good luck! The RAZR² V8 Luxury Edition is a very cool design phone!
Photos by Sergey Svetlitsyn.
Be careful with flashing it, V8 LE also has a lot of locked firmware.
malek79
сообщение 22.6.2023, 17:27
EXL,
I have a question about the Razr V3 series.
Do they have a custom firmware? Like custom themes etc.? If yes, which one is more popular?
Btw, I found a LE Razr2 V8 at a really good price, however the seller doesn't reply to my question about making a better photo of the phone. What a pity! I really hate those people! :/
сообщение 22.6.2023, 20:03
malek79,
Yes, both V8 and V3 series have custom firmware.
But V3 has a lot of modifications that are hidden behind one design. It can be:
V3 Classic Line: V3, V3r, V3re
V3i Line: V3i, V3e, V3ie
V3xx 3G Line: V3xx, V3xx AT&T (no front camera), M702iS
MS500 Line: MS500, MS500W
The V3re, V3ie are poorly customized.
The easiest way to find out which modification of the V3 series you have is by the firmware version.
fill.sa
сообщение 23.6.2023, 2:34
Из: Беларусь
Пользователь №: 223 758
Модель телефона: z6 V8
Прошивка: Linux SAedition MOD
По мне нельзя сравнивать дизайн v3 и v8. Да у v3 просто гигансткая слава и в свое время он был чуть ли не эталон. Но v8 я бы сказал просто другая лига, он просто в разы круче смотрится. Мне кажется v8 просто вышел в неудачное для моторолы время и прошел мимо публики и многие о нем даже не знают.
В свое время я хотел купить v3, до этого я уже не раз прошивал знакомым v3, но так чтоб свой иметь небыло, так вот я почти купил v3, но чудом попалась фотка v8, он нетак давно вышел, я стал искать и просто открыл новый мир для себя. В итоге продал свой сенсорный qtech и не думаю взял v8. Это к слову был мой первый магикс, вопреки тому, как многие начинали с z6, который мне в сравнении v8 казался старомодным уже, да оно так и было, по сути z6 это z3 чуть доработаный в плане дизайна. А v8 это просто уникальный в своем роде дизайн.
Сообщение отредактировал fill.sa - 23.6.2023, 2:36
сообщение 23.6.2023, 17:19
fill.sa,
Брат-близнец V9 по дизайну тоже был очень крутым. У него ещё и 3G HSDPA в преимуществах, но увы не такая интересная OS, там P2K. Зато работает ну очень быстро.
Кстати у меня где-то валяется CDMA-версия V9m, мне понравилось как там сделан динамик. Очень громкий и качественный, несмотря на толщину корпуса.
Интересно в V8 такой же или нет.
malek79
сообщение 24.6.2023, 14:02
EXL,
I found a basic Razr2 V8 model (again from T-Mobile) and the seller will test if it works first.
I really liked the LE one though!
Anyway, is custom firmware for the V8 (like this one: Прошивки для RAZR2 V8 under Мод-прошивки), are they risky to install? Which one is the most recommended one?
сообщение 24.6.2023, 14:55
malek79,
According to the MotoFan.Ru discussions these stock firmware are unlocked and safe to flashing.
1. General V8 512MB: R601_G_80.46.1BR_LP0039B_GCQLIDOTMCOREE.
2. General V8 2GB: R601_G_80.56.1BR_LP0039B_GSQLIDO2GBTMDE.
3. LE V8 2GB: R601_G_80.56.15R_LP0003C_GSQLIDO2GBLUXA.
but if you want you can install custom firmware, right but it's better not to do this, the operation of changing bootloader to NoRSA version is quite risky
you first need to update your bootloader to A3.CF then flash A3.CF NoRSA bootloader and then flash any custom firmware
Цитата(malek79 @ Сегодня, 21:02)
* Which one is the most recommended one?
I can't say 'cause I haven't used them, try to read the topics corresponding to custom firmware and choose the most interesting for you
fill.sa
сообщение 25.6.2023, 10:36
Из: Беларусь
Цитата(EXL @ 23.6.2023, 18:19)
* fill.sa,
Ну с позиции дизайна V8 и V9 один телефон. Разница только в толщине, ну и там чуть др технологические отверстия под платой. А половинка с экраном так вообще однин в один.
Я в свое время даже переставлял плату v8 в v9, чтобы получить больший АКБ.
По звуку на сколько я помню v8 тихий был, v9 лучше и наверное это с большим обьемом для динамика связано, опять таки из-за копрпуса потолще.
Цитата(malek79 @ 24.6.2023, 15:02)
* Anyway, is custom firmware for the V8 (like this one: Прошивки для RAZR2 V8 under Мод-прошивки), are they risky to install? Which one is the most recommended one?
Как вариант мог бы свой мод SAmod предложить. как минимум я могу отвечать на вопросы касаемо мода из остальных авторов уже никто не выходит на связь.
Сообщение отредактировал fill.sa - 28.6.2023, 5:42
malek79
сообщение 21.8.2023, 13:53
@EXL
Hello again!
I am back with a finally found V8 Luxury Edition in good condition.
However I noticed that the software is quite buggy and I want to update it.
As far as I know, the Luxury Edition was only available for retail market, right? Therefore there must be a safe and unlocked firmware for the phone right?
Thank you!
malek79
сообщение 21.8.2023, 13:58
The firmware installed on the phone is: R601_8.54.5DR_A
The bootloader version is: A3.CD
What do you think?
сообщение 21.8.2023, 15:16
malek79,
Hello!
Цитата(malek79 @ Сегодня, 20:53)
* As far as I know, the Luxury Edition was only available for retail market, right? Therefore there must be a safe and unlocked firmware for the phone right?
It's impossible to say for sure for some unknown firmware, unfortunately. SBF-Recalc has a SIM-Lock removal feature for any firmware but this will require some "not-so-obvious" manipulations.
There is a firmware for RAZR V8 2GB Luxury Edition that was flashed by forum users and it should be 100% without SIM-Lock, discussion here: Нужна прошивка к V8 с золотыми аналоговыми часами
I would do the following in your situation:
1. Сharge battery to 100%.
2. Switch to bootloader mode by pressing *, #, Red buttons together when phone is powered off.
3. Flash it from A3.CD to A3.CF bootloader using RSD Lite 3.8
4. Flash it to R601_G_80.56.15R_GSQLIDO2GBLUXAPMY084 firmware using RSD Lite 3.8
R601_G_80.56.15R is newer than R601_8.54.5DR_A many bugs can be fixed there.
Tools & Files:
1. 64-bit drivers: https://motofan.ru/downloads/200356/ | 32-bit drivers: https://motofan.ru/downloads/200358/
2. RSD Lite 3.8: https://motofan.ru/downloads/5002797/
3. A3.CF Bootloader: https://forum.motofan.ru/index.php?act=Attach&type=post&id=269477
4. R601_G_80.56.15R_GSQLIDO2GBLUXAPMY084 Firmware: R601_G_80.56.15R_GSQLIDO2GBLUXAPMY084_PDS010_LP0003C_GSQLIDO2GBLUXAPMY_S007_E002_R001_G001_1FF.sbf.7z
Good Luck and be careful!
malek79
сообщение 21.8.2023, 20:08
@EXL
Thank you for the information!
I discovered that SBF Recalc has the ability to verify if a flash firmware has a sim-lock.
Also the link to the firmware under "Tools & Files" gives an 404 error.
Can I use the mentioned file in the discussion you linked in the beginning of your post (in Russian)?
сообщение 21.8.2023, 20:12
malek79,
Sorry, fixed link is https://firmware.center/firmware/Motorola/R...G001_1FF.sbf.7z
Цитата(malek79 @ Сегодня, 3:08)
* Can I use the mentioned file in the discussion you linked in the beginning of your post (in Russian)?
Yes, it the same file.
malek79
сообщение 21.8.2023, 20:35
@EXL
Thank you again!
Btw are there any new features in the last Update like updated language support, etc.?
сообщение 21.8.2023, 20:43
malek79,
Unfortunately there is no official change logs but I think that there were only various bugfixes.
support for other languages can be installed using another lang packs e.g LP002EE: (British English, French, German, Portuguese, Russian, Spanish, Ukrainian)
malek79
сообщение 21.8.2023, 20:49
@EXL
I see! That's too bad.
About those language packs... are there also for supporting Arabic and Japanese script? Are they risky to install?
сообщение 21.8.2023, 21:24
Цитата(malek79 @ Сегодня, 3:49)
* About those language packs... Are they risky to install?
not risky as firmware
* are there also for supporting Arabic and Japanese script?
Language Package 0032 (Arabic, British English, French, German, Russian, Spanish, Turkish)
Language Package 0033 (Arabic, British English, French, Hebrew, Russian, Spanish, Turkish)
Language Package 0034 (Arabic, British English, Farsi, French, Russian, Spanish, Urdu)
Language Package 004F (English, Arabic, Hebrew, Russian)
Language Package 0050 (US English, Japanese)
Langpack with Arabic language probably exists but it is unlikely for Japanese because this phone was not sold there
malek79
сообщение 22.8.2023, 15:37
@EXL
Successfully flashed the phone!
Now for the language packs... Do you have a link to them?
сообщение 22.8.2023, 15:46
malek79,
There is no SIM-Lock in this firmware from the link, right?
Цитата(malek79 @ Сегодня, 22:37)
* Now for the language packs... Do you have a link to them?
No, I don't have them, the langpack will need to be made from existing firmware using SBF-Recalc tool.
What languages are you interested in?
List of available firmwares: https://firmware.center/firmware/Motorola/R...C%20RSD%20Lite/
List of languages: Motorola Language Packs Description 2007
malek79
сообщение 22.8.2023, 15:49
Yeah, as you said, no SIM-Lock and it's pretty responsive!
I want the language pack with the number 0032 (Incl. Arabic and German). They are important for me.
Didn't know that you need to extract them from a firmware.
malek79
сообщение 22.8.2023, 15:51
All in all I would like the language pack 0032 (Arabic, British English, French, German, Russian, Spanish, Turkish).
сообщение 22.8.2023, 16:00
malek79,
Try to flash this LP0032A language pack.
Прикрепленный файл RAZR2_V8_LP0032A.zip   ( 6.49 мегабайт ) Кол-во скачиваний: 82
malek79
сообщение 22.8.2023, 16:02
Alright.
But it won't harm the firmware itself?
сообщение 22.8.2023, 16:06
malek79,
It should replace the lang pack only.
If something goes wrong, just flash that full firmware again
malek79
сообщение 22.8.2023, 17:52
@EXL
Thank you very much!!
Everything was fine!
сообщение 22.8.2023, 17:56
malek79,
you're welcome
malek79
сообщение 24.8.2023, 10:04
@EXL,
Is there anything, that allows to customize the phone even more without deep intervention?
сообщение 24.8.2023, 19:32
malek79,
I doubt that without a deep changing and patching of firmware any significant customization is possible, except a changing of skins maybe.
Usually the phone customization process starts with a flashing of hacked NoRSA A3.CF bootloader and then flashing of some custom firmware:
1. NoRSA A3.CF Bootloader: https://forum.motofan.ru/index.php?act=Attach&type=post&id=190866
2. One of the latest custom firmware for RAZR V8, etc: Прошивка SAedition MOD для V8, Z6 и Z6W.
A bunch of different features appear after flashing some custom firmware, e. g. ability to install native games and applications from the following topics like Quake II and DOOM:
1. Project Evolution Packages
2. Нативные игры и эмуляторы
Reflashing is dangerous step especially for a rare and expensive RAZR2 V8 Luxury Edition so I do not recommend doing this on a collector's phone.
fill.sa
сообщение 17.12.2023, 2:01
Из: Беларусь
Я уже как-то рассказывал, что складная часть v8, такая же как у v9 и я лично их переставлял.
Честно уже не помню все ли на 100% там работало, но явных косяков точно небыло.
По случаю листал тут схемку и решил посмотреть, действительно ли оно там совместимо на уровне схемы.
В данном случаи мы даже сравним не разьеме складной половинки, а на разьеме на главной плате, т.е. у нас в цепь еще добавиться клавиатура, ее подсветка и боковые кнопки.
Отличия по контактам обвел красным. По сути отличия только в добавившихся дорожках для новых кнопак(у v9 их больше) и самое главное наверное это отличие в подключении подсветки клавитуры - полярность поменяна местами. На сколько помню у v9 подсветка клавы это обычные мелкие диоды, а у v8 это такой светящийся мат на всю клавиатуру, как я понимаю, так получался телефон тоньше на доли милиметра. Хотя странно зачем перевернули питание подсветки, на технологию подсветки это вроде никак не влияет.
Вообщем все как и говорил, на уровне второй половики все совместимо, разница только в клавиатуре.
сообщение 17.12.2023, 15:23
fill.sa,
Этот "светящийся мат" на всю клавиатуру называется EL-фольгой и он на многих телефонах Motorola был, начиная от V150, A630, почти полностью серия RAZR, и заканчивая RIZR/ROKR Z6 и RIZR Z8.
Очень странно что в RAZR2 V9 решили использовать светодиоды... Надо будет посмотреть, кстати, что в V9m заюзано: https://firmware.center/projects/EXL/Motoro...Prototypes/V9m/
Похоже что тоже LED-светодиоды вместо крутой EL-фольги.
MotoRAZR2 V8, Обсуждение · Motorola ROKR Z6, RIZR Z6, Z6w, RAZR² V8 · Forum
Текстовая версия Сейчас: 6.8.2025, 18:15
