11 страниц V « < 7 8 9 10 > »
Модинг , Тюнинг и прочие ковыряния е8., выкладываем и описываем тут
Zorge.R
сообщение 13.3.2010, 10:04
Group Icon
Группа: System Administrators
Из: рук в руки
Пользователь №: 101 800
Прошивка: 1CR
Цитата(croccio @ Вчера, 20:25)
zorge in your MP when light is off mgx doesn't work, why???
mgx it's just format of package. it may content binary file and shell script too. binary file can work in background. shell script will suspend, when phone backlight is off. it's phone feature, not z-mod.
i return to nik_envy, why the app that i do doesn't work??? =(
shell code performed only when phone active.
to prevent suspend script operation you can use zShRunEx_E8. it can take from Ant-ON.
croccio
сообщение 13.3.2010, 15:29
Пользователь №: 161 521
Модель телефона: L7 Slvr, c350
how can i control key press??? and the time of key press??? for example if key * for 3 second then...
(13.3.2010, 16:33):
zorge can u give me that program??? ant-on doesn't answer =(
Ant-ON
сообщение 14.3.2010, 6:43
Пользователь №: 49 304
Прошивка: CM12 / CM10 / PM2
For me it is not realistic.
Program include in app zSleepWithMusic and zNight. Download it and extract.
croccio
сообщение 14.3.2010, 11:05
where i put it ant-on??? in the folder of mgx??? i should edit it??? give me more info ant-on please!!! so i can't assign event when i press any key???
(14.3.2010, 12:07):
where i put it ant-on??? in the folder of mgx??? i should edit it??? and i add it to auto.run??? give me more info ant-on please!!! so i can't assign event when i press any key???
(14.3.2010, 14:04):
how can i make bin app??? is there any programa taht conveert sh to bin???
(14.3.2010, 14:36):
i do this:
cShut.lin
CODE
#!/bin/sh
mypath=${0%/*}
showRadio "cShut" "Seleziona opzione" "Avvia" "Aggiungi all'avvio" "Rimuovi dall'avvio"
case "$?" in
1)
    ores=`date +%k`
    minutis=`date +%M`
    ore=`showSlider "Impostare l'ora" "Ora sono le: $ores:$minutis" "0" "23" "$ores"`
    echo -ne $ore > ./ore.txt
    minuti=`showSlider "Impostare i minuti" "Ora sono le: $ores:$minutis" "0" "59" "$minutis"`
    echo -ne $minuti > ./minuti.txt
    showQ ""  "Programma avviato!" 2
    $mypath/zShRunEx -f $mypath/avvio.sh -c 1 -t 1
2)
    # Aggiungi
    cp -f ./S01cshut.txt /mmc/movinand1/unKnown
    showNotify "cShut" "Aggiunto all'avvio" 1 1
3)
    # Rimuovi
    rm -f /mmc/movinand1/unKnown/S01cshut.txt
    showNotify "cShut" "Rimosso dall'avvio" 1 1
exit 0
esac
avvio.sh
CODE
ore=`cat /mmc/movinand1/mpkgbox/cshut/ore.txt`
minuti=`cat /mmc/movinand1/mpkgbox/cshut/minuti.txt`
while [ $ore -eq $ore ]
do
sleep 55s
ores=`date +%k`
minutis=`date +%M`
if [ $minutis -eq $minuti ] && [ $ores -eq $ore ]
    then
              showNotify "" "le ore e i minuti sono uguali
fi
done
it doesn't work.
Zorge.R
сообщение 14.3.2010, 15:51
Group Icon
Из: рук в руки
Прошивка: 1CR
do this
  $mypath/zShRunEx -f $mypath/avvio.sh -c 1 -t 1 &
-t 1
it will start after 1 minute.
Добавлено позже (14.3.2010, 18:54):
2)
# Aggiungi
3)
# Rimuovi
to optimization this code you can do
if [ -f /mmc/movinand1/unKnown/S01cshut.txt ]
then
else
fi
croccio
сообщение 14.3.2010, 16:21
it doesn't work zorge! is there any program that convert sh to bin file??
Zorge.R
сообщение 14.3.2010, 16:35
Group Icon
Из: рук в руки
Прошивка: 1CR
no.
croccio
сообщение 14.3.2010, 16:51
so i can't do it =( how can i do to work it???
Zorge.R
сообщение 14.3.2010, 17:23
Group Icon
Из: рук в руки
Прошивка: 1CR
croccio, write binary.
or watch "cron" by roik-sv.
but, script do it work when back-light ON, only.
croccio
сообщение 14.3.2010, 17:39
how can i write binary??? can u give me th program??? i should use c+ and toolchain??? can u give me all the info?
ok zorge i see! thank u for all!
(14.3.2010, 18:42):
can u send me some link??? if i search in forum cron roik-sv it give me error
Сообщение отредактировал croccio - 14.3.2010, 17:48
Zorge.R
сообщение 14.3.2010, 18:48
Group Icon
Из: рук в руки
Прошивка: 1CR
croccio, roik-sv useful scripts
croccio
сообщение 15.3.2010, 16:41
i understand nothing =( however thank u for all your time =(
K()t
сообщение 18.3.2010, 18:51
Из: Niko City, Ukraine
Пользователь №: 202 229
Прошивка: CM
Что здесь не правильно почему не создаётся папка?
#!/bin/sh
mypath=${0%/*}
export PATH=${0%/*}:$PATH
mkdir -p /mmc/movinand1/.skin
cp $mypath/colors.css /mmc/movinand1/.skin/colors.css
cp $mypath/hsa_p.ini /mmc/movinand1/.skin/hsa_p.ini
cp $mypath/main_view.svg /mmc/movinand1/.skin/main_view.svg
mount -o bind /mmc/movinand1/.skin/colors.css /usr/data_resource/skin/default1/colors.css
mount -o bind /mmc/movinand1/.skin/hsa_p.ini /usr/data_resource/skin/default1/hsa_p.ini
mount -o bind /mmc/movinand1/.skin/main_view.svg /usr/SYSqtapp/xe/resource/skins/default/view/main_view.svg
echo "mount -o bind /mmc/movinand1/.sub/mainmenufolder.js /usr/SYSqtapp/xe/flows/mainmenu/mainmenufolder.js
          mount -o bind /mmc/movinand1/.sub/MainmenuFolder.xml /usr/SYSqtapp/xe/flows/mainmenu/MainmenuFolder.xml
          mount -o bind /mmc/movinand1/.sub/mainmenu.css /usr/SYSqtapp/xe/resource/skins/default/mainmenu/mainmenu.css" > /ezxlocal/download/mystuff/unknown/S10sub
kill `pidof am`
kill `pidof flowplayer`
showQ "zMod" "Выполнено" 2
Кирич
сообщение 18.3.2010, 20:45
Пользователь №: 215 200
Модель телефона: rokr E8
А как-нибудь вообще можно увеличить фото при звонке исходящем и входящем???
Sereg_k:
нельзя
Сообщение отредактировал Sereg_K - 18.3.2010, 22:14
Zorge.R
сообщение 18.3.2010, 23:06
Group Icon
Из: рук в руки
Прошивка: 1CR
зачем это в твоем скрипте?
а как ты проверял, создается или нет? может она скрытая, а ты не заметил pardon.gif
p.s.: есть чудо вещь, называется Вывод. При помощи вывода можно смотреть какие ошибки происходят в процессе выполнения кода. Если пишешь скрипты, имей привычку всегда смотреть вывод. особенно при первом запуске.
и еще:
оператор -p тут излишний, т.к. папка /mmc/movinand1 существует.
на z6 подбирали такой размер картинки, чтобы она занимала максимальную площадь.
214хнасколькототам.
у нас соотношение другое.
Zorge.R
сообщение 25.3.2010, 23:39
Group Icon
Из: рук в руки
Прошивка: 1CR
веб сервер и веб камера на Е8 -> подробней.
p.s.: знаю что не все пользователи ветки, заходят в подветку. поэтому решил опубликовать ссылку тут.
VoiD
сообщение 29.3.2010, 10:05
Пользователь №: 167 152
Модель телефона: EM30
Прошивка: 04.06e
Возможно ли уменьшить тайминги кнопок? Для более быстрого стирания текста, например.
K()t
сообщение 30.3.2010, 8:56
Прошивка: CM
А кaк то можно скриптом открывaть пaпки мeню нaпримeр игры или нaстройки?
Сообщение отредактировал K()t - 30.3.2010, 14:04
Zorge.R
сообщение 1.4.2010, 7:22
Group Icon
Из: рук в руки
Прошивка: 1CR
у меня есть извращенный способ для открытия папок в ФС.
для открытия папок меню, не знаю, даже не пробовал. скорее всего никак, особенно скриптом.
croccio
сообщение 1.4.2010, 9:37
how can i have continue vibration???
Сообщение отредактировал croccio - 1.4.2010, 10:52
Goin13
сообщение 2.4.2010, 21:33
Из: Червоноград
Пользователь №: 210 124
Модель телефона: Em30, a1200
K()t,
незнаю насколько полезный мой совет но, некоторые подпункты меню идут как приложение, их скриптом можно открыть(на крайняк, прописать в скрипте все подпункты скажем настроек) если заинтересовался смотри в sysRegistry, execID= (кажется)
Zorge.R,
а можешь поделится этим извращенным способом, если это конечо не секрет?
K()t
сообщение 8.4.2010, 11:20
Прошивка: CM
Кто-то пробывaл рeaльно встaвить в e8/eм30 BK70, или eто всё только чисто тeорeтичeски?
И eслe у когото стоит, сфоткaйтe кaк зaкрывaeтся зaдняя крышкa.
Сообщение отредактировал K()t - 8.4.2010, 11:38
Zorge.R
сообщение 8.4.2010, 12:04
Group Icon
Из: рук в руки
Прошивка: 1CR
Цитата(Goin13 @ 3.4.2010, 1:33)
можешь поделится
можешь. на следующей неделе.
execID=
это не подпункты и не меню и не папки, это приложения или скрипты.
Goin13
сообщение 10.4.2010, 7:00
Из: Червоноград
Zorge.R,
да, я неверно выразился. Но вот в чем суть: можно же создать скрипт скажем для пункта настройки и добавить туда все приложения из этого пункта. Получается какое ни какое а всетаки решение.
Zorge.R
сообщение 10.4.2010, 10:00
Group Icon
Из: рук в руки
Прошивка: 1CR
Goin13, можно. смотри zMod-Config из сборки 2.4.5.
но к папкам отношения не имеет, это скрипты. думаю вопрос был о папках "органайзер", Настройки, Игры, Мультимедиа.
по поводу папок в фс, надо монтировать фейковый майстаф.кфг (смотрите zroot), затем запускать файл менеджер (mystuff), он будет открыт в папке указаной в фейковом конфиге, после закрытия файл мена, конфиг надо отмонтировать. (опять смотреть zroot)
K()t
сообщение 10.4.2010, 11:07
Прошивка: CM
Goin13, я спрашивал в основном за игры, чтоб можно было повесить на кнопку вызова скрипт с возможностью запуска зТаскМена и папки Игры
Goin13
сообщение 10.4.2010, 15:18
Из: Червоноград
K()t,
просто добавь в таскМан яву.Или faultline main menu(откроет меню).
Zorge.R,
спасибо, вроде разобрался.
Diag
сообщение 10.4.2010, 15:28
Из: г. Краснодар
Пользователь №: 171 112
Прошивка: R6716_G_71.04.06R_C
Ребят, скажите, нужно написать скрипт, который скрывал! определенный процесс. Это возможно? Какая команда для этого нужна?
K()t
сообщение 10.4.2010, 15:31
Прошивка: CM
Goin13, А меня все около 50ява приложений и игр которые лежат в четырех папках а добавлять их в зТаскМен не удобно и долго искать нужное приложение во всем списке.
Добавлено позже (10.4.2010, 18:33):
Diag, а зачем тебе скрывать процессы, а главное от кого ты их хочешь скрыть?
Diag
сообщение 10.4.2010, 16:00
Из: г. Краснодар
Ну чтоб понятнее было: свернуть процесс. Ладно, забудем. Вот предложение: при новых библиотеках, управление rockbox'a меня устраивает, а не устраивает его сворачивание, когда тебе позвонят. Можно было бы написать в скрипте (который висит на зеленой кнопке и запускает ztaskman), перед "запуском" диспетчера написать команду, к примеру, свернуть процесс rockboxui, и по длительному нажатию на зеленую кнопку можно было свернуть плеер. Товарищи, не знаю, прокатит оно, или я бред пишу. Можно так сделать?
Goin13
сообщение 10.4.2010, 19:51
Из: Червоноград
K()t,
да-а... Прописывать в скрипте все приложения смысла нет. Тогда я понятия не имею что делать.. Сдаюсь
Zorge.R
сообщение 10.4.2010, 21:02
Group Icon
Из: рук в руки
Прошивка: 1CR
свернуть отдельный процесс у нас нельзя, по словам Ant-ON'a.
можно только свернуть все.
Сообщение отредактировал Zorge.R - 10.4.2010, 21:08
Diag
сообщение 11.4.2010, 6:32
Из: г. Краснодар
Ну а как тогда все свернуть (какой командой?)? Можно было сделать так: чтоб при вызове диспетчера задач, все подряд не скрывалось, через if проверить, запущен ли rockbox, если запущен, то выполнить команду свернуть все и запустить ztaskman, а если нет, то просто открыть ztaskman. Это хоть реализуемо?
Goin13
сообщение 11.4.2010, 7:16
Из: Червоноград
Сворачивать пробовал, ничего не получилось(таскМан открылся но потом поверх него вылез рокбокс, играть не перестал) и вот подумал, если убить рокбокс? Впринципе там есть возможность продолжить проигровать треки с прошлого запуска.
Diag
сообщение 11.4.2010, 8:24
Из: г. Краснодар
Запуск диспетчера задач поверх rockbox ничего не даст - управление принадлежит плееру, в ztaskman ничего не сделаешь. А я предлагаю, чтобы перед самым запуском ztaskman выполнялась команда, которая бы сворачивала все. Может, тогда свернется плеер, и управление передастся телефону, а не rockbox'y.
З.ы. Что то мне кажется, я уже повторяться начал.
Goin13
сообщение 11.4.2010, 8:31
Из: Червоноград
Diag,
я понял. И команду на сворачивание прописал в скрипте запуска таскманеджера, что получилось я уже писал. Предлагаю вместо сворачивания убить рокбокс, потом по необходимости по новой его запускать и брать "продолж. воспроизведение"
Diag
сообщение 11.4.2010, 9:17
Из: г. Краснодар
А какую ты команду использовал для сворачивания? Можешь поделится? Или дай кусок скрипта, где эта команда работает.
Goin13
сообщение 11.4.2010, 9:52
Из: Червоноград
Diag,
использовал stop. Куска скрипта не дам, так как нет у меня скрипта куда этот самый стоп можно лепить хоть с каким-нибудь ощутимым результатом(хотя должно работать, в базибоксе есть). А kill у меня работает, потому и предлагаю.
Diag
сообщение 11.4.2010, 11:16
Из: г. Краснодар
А смысл использовать "убийство", если можно просто выйти из плеера, а потом продолжить воспроизведение?
Goin13
сообщение 11.4.2010, 12:42
Из: Червоноград
Diag,
смысл в том что при визове из рокбокса он не будет "мешать" таскМану (незнаю как у кого, а у меня начинаются очень досадные глюки с управлением,иногда музыка начинает орать а остановить не получается).
Модинг , Тюнинг и прочие ковыряния е8., выкладываем и описываем тут · Motorola ROKR E8, EM30 · Forum
Текстовая версия Сейчас: 25.7.2025, 15:20
