5 страниц V « < 3 4 5 >
Прошивка Basic Plus, V8
abelenki
сообщение 13.4.2009, 2:44 Закрепленное сообщение!
Из: Russia, Perm
Пользователь №: 94 097
What is Basic Plus?
It is a basic unbranded NO_RSA firmware based on 80.46.1BR for 512MB V8 and 80.56.1BR for 2GB V8 with added 5 customization menus
(Change Bootlogo, Font Changer, Startup-/Shutdown Sound, Alarm Clock Timer and Reminder Sound), USB-Lan and Swap memory by default. That's it!
Now this space saving allowed to return to the old system of changing the language by flashing the CG46.
That is the Basic part!
The Plus part includes a Package Manager and you can install what you want and leave out what you don't want. There are 18 packages supplied, which would include the complete Evo 3 range, some have been upgraded, like zLauncher is version 2.1, pictureflow is upgraded and SlideShow is a development of pictureflow made by DeJe. You just have to copy the packages (*.tar.gz files) into /ezxlocal/download/mystuff/package. The Package Manager (you find it in the Package folder in the Main Menu) will install and uninstall packages. During installation you have to enter a menu name, for example you install zLauncher then you can call the menu whatever you want (e.g My Filesystem or Mein Dateienfresser), which is nice if you do not use english as your language. Secondly during installation you can associate file extentions, which most packages do not need. Also, because most Mods now come with a selection of languages and the packages are installed in /ezxlocal/download/mystuff/packages/apps, which is read/write filesystem, you can change the menus to your language. All packages menus will be installed in the Package folder below Package Manager, you either leave them there or you move them to somewhere else, your choice.
USB-Lan and Swap Memory are in the Settings menu, USB-Lan at the beginning and Swap Memory at the end, as you need to use Swap Memory only once to set up the swap file and activate it. After each reboot the swap file gets automatically activated. I have not included the Java HEAP Setting package as I have set the the default HEAP size to the maximum of 4096KB by default.
If you really MUST use Windows Explorer instead of FTP then shutdown the swap file first then change to USB Setting Memory Card and connect with USB cable to PC, the V8 will not hang itself.
MPlayer, because of its /mmc/mmca1/Programms path requirement has been not supplied as a package. However the MPlayer menu exists under Multimedia and all you have to do is copy the included MPlayer folder into /ezxlocal/download/mystuff/Programms on the 512MB V8 or into /mmc/mmca1/Programms on the 2GB V8, that's all.
Another change is that the ezx_flexbit.cfg is now under /ezxlocal/download/appwrite/flexbit, this allows to change the flexbit without the need to flash a CG43 every time you edited the ezx_flexbit.cfg. Just copy your new ezx_flexbit.cfg file into this folder and reboot.
I have tried to make this firmware as simple as possible, as from the comments about Evo 3 saw that a lot just could not get the hang of the different language system and how to handle it.
The need for a Package Manager was always high on the list, also the result of comments and requests like "we do not need this, but can we have that..." and then "we do not need that, but can we have this...", so now everybody can decide themselves what they want and what not.
There are already 2 package management system around (PEP and mpkg), so why creating a new one? Well, I was hoping that there would be a PEP for V8, but that project got put on hold and by request of the PEP creators I could not port it to V8, so that left only mpkg. Now mpkg might be fine for the Z6, but it is not good enough for the V8 and the reasons are that mpkg packages are installed from and onto the Z6 SD card (/mmc/mmca1) this path exists only on 2GB V8, but not on 512MB V8, secondly mpkg packages for Z6 do not work on V8, they need modification in order to work on the V8 (huge potential for future post " I installed mpkg package, but it does not work ."). Thirdly the icon management of mpkg produces only black exclamation marks on yellow background (mpkg uses one icon for std and ani icons, no small icon). which honestly does not look nice to have on your phone. Fourthly the AppID creation is rather simple and the V8 always has been quite fuzzy with "home made" AppID's. So, I either rewrite mpkg to fit V8 and change Z6 mpkg packages into V8 mpkg packages, which still leaves the door wide open for people to install Z6 mpkg packages on V8 and wonder why they do not work. So I decided against that option and created my own package management. Anyway Linux is all about choice, so there you go!
You might find that the Customize menu looks a bit different, this was done on purpose.
OK, I could not have done this without the help, inspiration and testing from DeJe (faq4mobiles.de) and DaRk_dOg (MMUS et al.), their work, ideas and contribution helped to shape this firmware. THANKS!
But a big thank you has to go out to all the other unnamed modders, who's work, modified or not, found their way also into this firmware. THANK YOU!
As with all my work, this firmware is also free for everybody to change, use parts of it or simply print out the code and wallpaper your room with it.
Автор:
rasputin007
Оригинальный топик:
modmymoto.com
Описание:
1. Прошивка No RSA.
2. Лэнгпак шьётся по-старому, через RSDLite.
3. Теперь дополнительные программы устанавливаются пакетами, аналогично PEP, только они имеют свой формат. (т.е. теперь можно выборочно ставить то, что тебе нужно). Пакеты нужно копировать в /ezxlocal/download/mystuff/package, а потом инсталлировать или дизинсталлировать через Package Manager. В процессе инсталляции пакета, вы можете присвоить ему любое имя, а также ассоциировать с ним любые расширения (для большинства пакетов это не нужно).
4. USB-Lan и Swap Memory находятся в меню Settings. Swap Memory нужно запустить и настроить всего лишь один раз. Он активируется автоматически после ребута или включения телефона.
5. Если не активировать файл подкачки (Swap Memory), телефон теперь можно подключать в режиме мемори-карты, и при этом он зависать не будет.
6. Java HEAP автоматически установлен на максимальное значение - 4096KB.
7. MPlayer не включен в виде пакета, а устанавливается по-старому. Т.е. просто скопируйте его в /ezxlocal/download/mystuff/Programms на V8 512MB или в /mmc/mmca1/Programms на V8 2GB. Ярлык на него уже установлен в прошивке и находятся в Multimedia.
8. Файл ezx_flexbit.cfg теперь находится по этому пути - /ezxlocal/download/appwrite/flexbit. Теперь его можно спокойно редактировать, перезаливать в телефон и перезагружаться, чтобы изменения вступили в силу (разборка, редактирование, сборка и прошивка CG43 больше не требуется).
9. Видео-камера теперь снимает в разрешении 352x288.
Порядок прошивания:
1. Bootloader A3.CF (если у вас какой-либо другой бутлоадер).
2. Bootloader A3.CF No RSA.
3. Прошивка Basic Plus Update (прошивайте версию прошивки, соответствующую вашей модели телефона - 512MB или 2GB. Для Luxury Edition прошивайте версию 2GB).
4. Лэнгпак LP002EE.
Файлы:
Bootloader A3.CF
512MB Basic Plus Update
2GB Basic Plus Update
LP002EE - UK English, German, Russian, Ukrainian, French, Spanish & Portuguese; Russian voice commands only
Basic Plus Update Packages
MPlayer
V8 Modding Guide
Сообщение отредактировал XXX_S_B - 20.2.2013, 16:09
KoJIoBASS
сообщение 1.12.2009, 16:23
Пользователь №: 174 352
Модель телефона: RAZR 2 V8 2Gb
Прошивка: Fusion 3
Ещё одно адаптированное приложение под эту прошивку DosBox
Оригинальный топик DosBox for Z6
Заработало после перезагрузки телефона. Свап на телефоне активирован.
Разбираюсь с keymap, а то непонятно как этим пользоваться.
Добавлено позже (1.12.2009, 17:24):
любопытнный
сообщение 1.12.2009, 18:22
Пользователь №: 183 849
Модель телефона: Motorola Accompli 008
Прошивка: ОЧЕРЕДНАЯ
KoJIoBASS, Рокбокс последний нет желания прикрутить,ту версию,которая через иконку сворачивается-разворачивается?
KoJIoBASS
сообщение 1.12.2009, 18:30
Прошивка: Fusion 3
любопытнный, попозже постараюсь взглянуть
Vermin
сообщение 3.12.2009, 0:38
Пользователь №: 64 122
Модель телефона: V635; V8
Прошивка: Своя; Basic Plus
Последний это какой. У меня 3.4 но не могу понять как через иконку сворачивается?
любопытнный
сообщение 3.12.2009, 18:30
Прошивка: ОЧЕРЕДНАЯ
Vermin, У меня просто 3 версия,которая сворачивается при закрытии флипа,а разворачивается только через Таскмэн.В ветке Рокбокса версии 3.4 для Бейсик+ нет.Если можно выложи свою плиз.
Vermin
сообщение 4.12.2009, 0:19
Держи.
Я просто особой разницы в них не увидел. Поэтому не выложил.
prSapphire
сообщение 7.12.2009, 15:26
Из: Владивосток
Пользователь №: 56 874
Модель телефона: Atrix 4G/Milestone
Прошивка: MIUI v4/MIUI GB
в ожидании чуда ))
Подскажите, а последний Рокбокс под 512 версию подходит? То он у меня установился, но не запустился. sad.gif
Если что нужно изменить подскажите, чтобы и вам еще раз не выкладывать и мне повторно не качать smile.gif
у прошлой версии было неудобно одно, ее нельзя было свернуть, а закрытые флипа приводило к закрытию приложения. Слушать не удобно sad.gif smile.gif smile.gif sad.gif
спасибо заранее
Martein
сообщение 13.12.2009, 14:55
Пользователь №: 112 635
Модель телефона: Razr2 V8
Прошивка: R601_G_80.56.1BR
Подскажите куда нужно помещать пакеты для Package manager'а...
По этому пути папки package не было, я создал поместил туда архив snesx.tar.gz но программа так и не видит его.
Разобрался, правильный путь
/mmc/mmca1/package
в шапке следовало бы поправить.
Но вот второй вопрос - Mplayer скопировал по инструкции в папку:
и пробовал сюда тоже попробовал на всякий случайю
/ezxlocal/download/mystuff/Programs
но не запускается почему то...?
Сообщение отредактировал Martein - 13.12.2009, 19:04
KoJIoBASS
сообщение 13.12.2009, 19:51
Прошивка: Fusion 3
Читай внимательнее этот пост
Особенно обрати внимание на версию своего телефона , у тебя, судя по подписи, 2Gb, путь другой...
А содержимое архива, это папка с MPlayer-ом в папке Programs должна лежать. На всякий: тел ребутни после этого
Сообщение отредактировал KoJIoBASS - 14.12.2009, 19:41
Martein
сообщение 14.12.2009, 16:06
KoJIoBASS,
чем отличается путь куда я копировал от того что ты сказал?
KoJIoBASS
сообщение 14.12.2009, 19:45
Прошивка: Fusion 3
Просто сам в первый раз кинул содержимое архива, в нем несколько подпапок было, поэтому и написал что кидается для твоей модели /mmc/mmca1/package папка MPlayer
Martein
сообщение 15.12.2009, 11:19
KoJIoBASS,
т.е. я должен скопировать папку Mplayer сюда?
/mmc/mmca1/package/MPlayer
prSapphire
сообщение 15.12.2009, 14:25
Из: Владивосток
в ожидании чуда ))
Простите за назойливость, но мне кто нибудь сможет дать ответ на мой вопрос? sad.gif
Просто на вопросы которые уже десятки раз обсуждали ответы поступают снова и снова, я как бы не против, но складывается ощущение что люди не хотят читать ( или не умеют) совсем. Обидно sad.gif
Так все же как заставить работать последний rockbox на телефоне версии 512 мб. Реально ли вообще?
Заранее спасибо за потраченное время.
KoJIoBASS
сообщение 16.12.2009, 13:39
Прошивка: Fusion 3
Я сделал последнюю версию RockBox 3.4 но для 2Gb, если кому нужно- выложу, но там при закрытии флипа rockbox сворачивается же...
Сообщение отредактировал KoJIoBASS - 16.12.2009, 13:45
Vermin
сообщение 17.12.2009, 0:41
не знаю, извините я им не пользуюсь.
KoJIoBASS
сообщение 17.12.2009, 11:31
Прошивка: Fusion 3
Цитата(Vermin @ 17.12.2009, 0:41) *
Да, точно smile.gif немного пропустил
Добавлено позже (17.12.2009, 11:38):
Цитата(prSapphire @ 15.12.2009, 14:25) *
...Так все же как заставить работать последний rockbox на телефоне версии 512 мб. Реально ли вообще?
Так у тебя не запустилось приложение что Vermin переделал?
NitrogeN
сообщение 20.12.2009, 0:18
Мотодизайнер
Пользователь №: 67 007
Модель телефона: iPhone 5
^______^
после установки апдейтера пакет мэнэджер нехочет ничего ставить и удалять... Как пофиксить?
NitrogeN
сообщение 20.12.2009, 8:39
Мотодизайнер
^______^
Уже ненадо... Прошил по новой...
KoJIoBASS
сообщение 20.12.2009, 16:21
Прошивка: Fusion 3
К вопросу о профилях, только у меня при включении на телефоне выбран профиль "Мелодия и Вибрация"?
Причём не важно какой ставлю, после выключения и очередного включения профиль снова "Мелодия и Вибрация".
Vermin
сообщение 21.12.2009, 0:11
У меня все нормально. Какой выбираю, тот и остается.
prSapphire
сообщение 22.12.2009, 13:56
Из: Владивосток
в ожидании чуда ))
Насчет стилей оповещения, советую их сначала сбросить до стандартных настроек, а потом они работают как надо. Какой поставишь тот и будет стоять. У меня так, во всяком случае, эта проблема решилась smile.gif
У меня такой вопрос, кто нибудь знает нормально работающий ява плеер на этой прошивке? KD Player, XploreME - не предлагать. Первый не проигрывает файлы, второй вообще отказывается устанавливаться sad.gif
Заранее моя благодарность.
KoJIoBASS
сообщение 24.12.2009, 6:24
Прошивка: Fusion 3
Так у меня на стандратные настройки не получается скинуть с момента прошивки, причём несколько раз перешивал одно и тоже. smile.gif
prSapphire
сообщение 24.12.2009, 6:39
Из: Владивосток
в ожидании чуда ))
KoJIoBASS,
Это и у меня также, но я говорил не про эти настройки. Заходишь в настройки профиля, выбераешь первый, и в нем уже сбрасываешь. Там прямо будет сбросить надпись. А дальше уже редактируешь профиль по своему усмотрению. Только сохранять ничего не надо, выходишь спокойно и твой профиль нормально начинает работать и меняется уже легко. У меня такой вариант сработал.
Кстати, я тут немного изменил Customase под себя, чтобы не ставить лишние пакеты. Туда впихнул некоторые вещи, как: v8SYSinfo, cpu_frequency, equalaiser, weblink - для смены ссылок HSA. Могу выложить, если надо. Там по большому счету все на русский язык переведено, а в старых исправлены орфографические ошибки. Пока только нормальных иконок не добавил.
Сообщение отредактировал prSapphire - 25.12.2009, 11:22
KoJIoBASS
сообщение 24.12.2009, 17:01
Прошивка: Fusion 3
Цитата(prSapphire @ 24.12.2009, 6:39) *
KoJIoBASS,
В каком именно пункте и что нужно сбросить?
Цитата(prSapphire @ 22.12.2009, 13:56) *
...кто нибудь знает нормально работающий ява плеер на этой прошивке? KD Player, XploreME - не предлагать. Первый не проигрывает файлы, второй вообще отказывается устанавливаться sad.gif
Добавлено позже (24.12.2009, 17:03):
RockBox непонравился?
Добавлено позже (24.12.2009, 17:09):
Про сброс профиля, нашёл. Нужно в настройках профиля нажать кнопку "Функции", затем сбросить.
Теперь у меня телефон стартует с другим профилем biggrin.gif "Только вибрация" spiteful.gif
Сообщение отредактировал KoJIoBASS - 24.12.2009, 17:04
prSapphire
сообщение 25.12.2009, 11:17
Из: Владивосток
в ожидании чуда ))
KoJIoBASS,
И это лечить можно. Говорю же, сначала зайди в профиль и выбери всё что тебе нужно для настройки, но не сохраняй. И всё, профили начинают работать нормально. Правда иногда еще может потребоваться переход с профиля на профиль посредством решетки. Вот и всё.
Rockbox, это не совсем ява плеер. Во первых он весит вместе с либами почти 30 метров, во вторых, его в фон свернуть нельзя на телефонах 512 мб. А ходить с раскрытым телефоном в кармане не удобно как-то :-)
Vermin
сообщение 26.12.2009, 9:07
А чем вам не угодил стандартный плеер? И телефон закрыть можно и управление сенсорными клавишами.
prSapphire
сообщение 26.12.2009, 16:36
Из: Владивосток
в ожидании чуда ))
В стандартном плеере не очень удобно реализована сортировка файлов. Он берет всё подряд не взирая на папки, поэтому перепадают и рингтоны просто. Так как у них тоже теги заполнены то часто создавать плей листы не удобно. Попадают не сами песни, а их куски. Короче, хлопотно немного
Alexmonster
сообщение 22.1.2010, 10:35
Пользователь №: 165 370
Прошивка: R601_G_80.42.3BR
Поставил данную прошивку на 512.Все работает с английским ленгом. Решил русифицировать: открыл прошивку программой SBF-Recalc 1.2.8, заменил сайл CG41, собрал сновай и этим прошил через RSD Lite 3,9. Если я правильные мануалы курил вроде все рпавильно сделал, но русского языка в телефоне так и не появилось:(. Подскажите что я сделал не так?
Сообщение отредактировал Alexmonster - 22.1.2010, 10:37
prSapphire
сообщение 22.1.2010, 10:49
Из: Владивосток
в ожидании чуда ))
Alexmonster,
а просто прошить ленгпак из закрепленого сообщения не пробовал? Ничего и пересобирать не надо, просто шьешь его поверх.
Квадратов вместо букв не бойся. Потом смени шрифт через customise на default
и будет тебе Щастъе :)
Alexmonster
сообщение 22.1.2010, 11:40
yesyes.gif спасибо, все отлично работает!
vanzan
сообщение 27.1.2010, 6:59
Пользователь №: 213 047
Модель телефона: v8
аналогично pep пакетам
а можно пеп переносить сюда???
Vermin
сообщение 27.1.2010, 8:25
Можно, но только содержимое и то не все.
vanzan
сообщение 27.1.2010, 12:33
Модель телефона: v8
Может мануальчик кто нить напишет?
кстати для v8 2gb /ezxlocal/download/mystuff/package нетакая директория. У меня /mmc/mmca1/package
Сообщение отредактировал vanzan - 27.1.2010, 13:08
strader
сообщение 27.1.2010, 19:42
Пользователь №: 199 303
Модель телефона: V 360
ну а по поводу работы телефона в режиме флешки скажет кто нибудь что??
не работает cry.gif пишет "вставте диск в дисковод" и по поводу подождать, час ждал, и ничего shok.gif
Advokat_d
сообщение 27.1.2010, 22:16
Пользователь №: 155 462
Модель телефона: V3i,V8 2гига
Прошивка: R601_G_80.56.15R
Ставишь стандартый скин( текоторые по умолчанию) И вперед!
Vermin
сообщение 28.1.2010, 0:21
Еще нужно swap отключить.
strader
сообщение 28.1.2010, 8:49
скин плуш стоит, своп отключен и все равно не заходит ::(
может еще разок перешить??
Advokat_d
сообщение 28.1.2010, 23:34
strader
сообщение 31.1.2010, 15:54
перешил и все так же осталось...
KoJIoBASS
сообщение 31.1.2010, 17:27
Прошивка: Fusion 3
to strader
С телефона на карту памяти заходит?
В настройках тип соединения какой выбран?
Пробывал ли на другом компьютере подключать? (Если ОС Windows- такие ошибки как "вставьте диск" встречаются)
Сообщение отредактировал KoJIoBASS - 31.1.2010, 17:28
Прошивка Basic Plus, V8 · Motorola ROKR Z6, RIZR Z6, Z6w, RAZR² V8 · Forum
Текстовая версия Сейчас: 18.7.2025, 13:58
